Posts by ukslc
    Exact same problem since latest firmware downloaded...... other posts here show similar problems...
    Have to re-load every morning, or whenever box put on standby (except if restarted within a few minutes). VOD seems OK, just the live TV has the problem.
    With or without VPN. MOL2 or other app no difference. Static IP address or DHCP. Factory reset - no difference. No issue with Z8 sleep timer. Also checked with provider, who re-started service for me - no problems at their end. (Settings say box is connected to Provider even when live TV screen is black- have to dis- and then re-connect...
    Live TV seems to be OK for a couple of hours now - was only 10-30 minutes at first...
    Thanks for taking the trouble to post this!...
    Sleep Timer was Off
    Playback Limit in Settings cannot be altered - set by Provider no doubt - has always been 3 hours but not had any similar issue before latest Updates (when problem first developed recently, it was going off after minutes/ or 2 hours, rather than a full 3 hours ....and wouldn't that just cause the box to go to Red Light/Standby, rather than me having to re-start the service every time? ...(it says Connected and MOL2 menu etc is there, but black screens and I have to dis- and then re-connect).....
    Lease Time on Router seems to be every 24 hours. ......
    Cheers
    Anyone else still having problems following the update?....my Z8 still freezes/crashes every 2-3 hours - always reloads OK. Tried factory reset, VPN, static IP address, different App (STB emu), all with no difference.....contacted Provider, who re-started the service for me but confirmed all was OK at their end.....is there any new Firmware update to come?.......
    I'm having exactly same issue since the update.....TV and VOD loads up OK from a restart but black screens after a few minutes (channel name etc still there - just black screen) - Loads up again OK each time, but then crashes again etc....only since update...even crashes whilst on standby, so if I turn it off when it's OK, and then turn on later, black screen from outset...(it says it's connected to the portal in the settings). No difference if use VPN or not.
    Have cleared cache and done factory data reset etc, but can only download latest MOL2, so issue still arises...
    Worked perfectly with previous MOL2 version - I wish I han't done the update and could go back to that !....as it stands, box is unusable - help!
