Since a week, or so, all the movie group in MYTV+ or MYTV3 ask for the pin code, just like the adult group.
In other apps, it doesn't, with the same "service".
Any thoughts?
Cheers
Any thoughts?
Cheers
Hi to all of you
I have a Z11 PRO MAX, but it's locked to a provider. It doesn't let me add any other source.
Already tried factory reset, but it remains with the same issue.
Any thoughts?
regarding VOD can't load issue , there were same cases before
try to factory reset or requiere new account and test it without share with another box.
HI,
First of all, thank you for your comment.
Factory reset and new account, and the problem continues.
Cheers
Z10 PRO MAX, Z8 PRO and Z+NEO
Since last MYTVONLINE 2 update, I'm having issues with the VoD.
Most of the time, it doesn't open.
Does anyone else has this problem?
Thank you
Is there any reason why Z10 is not compatible with AirSync?
Do you advise any other app to remote control by SmartPhone?
Best regards
In my Z+, the remote stoped working, except for the TV button.
Changed batteries, but still the same...
Is there a chance to make a hard reset on the remote only?
