Posts by PeterT
    Hi guys and dolls.
    I need some help since I got this problem with connecting my keyboard and mouse to the Z8 (not pro).
    I have 2 Unifying dongles since I found one I thought I lost. 😂
    They both works fine on the PC and I programmed one of them to pair with my kb and mouse. worked perfectly.
    Then I took out the Unifying receiver from the PC and put it the USB 2,0 slot on the box. Nothing!
    When I go into settings on the Z8 I can see that it reads Logitech Unifying on the external keyboard tab, but it won't work.
    Or to be honest, it worked for about 10 seconds.
    Since then i have done it all over, pairing an such but ending up with the same crap. Nothing.
    Restarted the Z8, plugged it out for a couple of minutes etc. But no.
    Am I doing something wrong or doesn't the Z8 work at all with the Unifying dongle?
    Would be very grateful if I could get som advice on this problem.
    Thanks in advance.:smiling_face:
    Hi!
    I can't manage to do a backup.
    I formated the USB-stick with Rufus acc to the instructions given in this forum,
    put the stick in the slot and restart the box.
    When i go into settings back up the text is dark but I can tick in the box for wich usb to use.
    In the menu on the right it say backup and the size and below that is the start back up button.
    The menu on the right with the size is a little brighter than the rest of the text but the start button is darker.
    When I press it it lights up a little but nothing happens and when I try again It wont let me choose wich usb-device.
    I do the whole shebang from the top once again with the same result.
    Can someone help me?:confused_face:
