Hi guys and dolls.
I need some help since I got this problem with connecting my keyboard and mouse to the Z8 (not pro).
I have 2 Unifying dongles since I found one I thought I lost. 😂
They both works fine on the PC and I programmed one of them to pair with my kb and mouse. worked perfectly.
Then I took out the Unifying receiver from the PC and put it the USB 2,0 slot on the box. Nothing!
When I go into settings on the Z8 I can see that it reads Logitech Unifying on the external keyboard tab, but it won't work.
Or to be honest, it worked for about 10 seconds.
Since then i have done it all over, pairing an such but ending up with the same crap. Nothing.
Restarted the Z8, plugged it out for a couple of minutes etc. But no.
Am I doing something wrong or doesn't the Z8 work at all with the Unifying dongle?
Would be very grateful if I could get som advice on this problem.
Thanks in advance.![]()
