Nothing is working. Was sure hoping for something other than factory reset. I have a lot setup on there.
Posts by Jeffp
I should also add that it's 100% a problem with the actual streaming of video. Every app, I can login to, see the guides, what's playing, etc. Select the channel or movie and as it tries to start playing is when it fails with video errors.
Yup, it sure is.
My GTV has been working great since I got it a couple months ago. This morning I can't stream a single thing. Every app that I try, MyTV, Plex, HBO,YouTubeTV everything fails with various streaming errors.
I've rebooted,unplugged the power, removed Wi-Fi settings and reapplied, nothing works.
No it's not an issue with my wifi or internet, every other device in the house works fine. Definitely a problem with the GTV box.
Anyone run I to this issue? I'm really hoping a factory reset isn't the fix. That's going to be a massive pain in the a$$.
Thanks in advance
Google TV is not Android TV rebranded. It's a totally new interface. Does not even function the same. I have both, and they are very different.
Just got my GTV and regardless what app I try, MOL2, StbPro all video freezes. I've tried StbPro with same portal info on my Nvidia Shield and it works fine.
I have strong Wi-Fi speeds to the GTV (403mbps) all updates have been applied.
All other streaming apps, YouTube, Hulu, Disney+, etc work without issues.
Anyone else have this issue?
Any ideas?
Thanks in advance.
