Thks all for your answers about the availability of the bêta version.
Posts by LeCob58
Home / Mode / Standby
it does not change anything, my TV doesn't switch OFF with the Z8 remote. Very strange because switch ON works well....
For the sound, it's finally ok, it works (not with the main volume button but the ones with front white color in TV Control).
Set box power to: Standby.
sorry, what do you mean by standby ? Where I find this ? Thks
Do I have as well to enable System Sound or not with my sound bar ?
Ok thks, I'll try when back home and let you know.
Hi all,
I just bought a Z8 Pro to replace my Nvidia Shield who will be used with another TV. I have 2 problems, I put setting (CEC) into Z8 to switch ON/OFF my Laser TV and as well my Sound Bar with the Z8 remote but it does not work well.
Switch ON is ok but Switch OFF does not work for my TV.
The Sound Bar is connected HDMI on my TV but I can't change the sound volume.
I hope to be clear in my explanation, not really sure.....🥴
Thks for your help.
