sorry! found the answer in support, must be my provider.
Posts by valaore
I am not able to change playback limit in mytvonline2 for GTV, its grayed out and set to 3h. Am I missing something?
/David
haha i actually will! so sick of samsung user support!
even though I guess they will ignore me it would be nice to be able to provide the rcu keys to them. Can they be found in the box somewhere for me to extract or in some other place online?
stay safe
well guess it can be seen that way. But I really think a new Formuler box should interpret signals as all other Formuler boxes in order to avoid issues like this..
Samsung is not known for fast support
From where can one get the GTV RCU keys?Thanks
/David
well, clearly the GTV does not work with the Formuler settings in the Samsung RCU/Provider database.
- If I use the GTV box as unrecognized by Samsung TV almost all buttons work via CEC except most important one, channel button for zapping.
- If I identify the GTV box s a Formuler box from the Samsung RCU/Provider database nothing works.
SAM can one request somewhere for a fix that the GTV box behaves as other Formuler(I think it really should as its a Formuler box
) boxes when being controlled by Samsungs Formuler RCU/Provider template in their database?Thanks
/David
ahh ok,
anyways you can confirm that you use Samsungs One remote, set via universal remote to formuler and the channel up/down button work for zapping? If so the issue should be at my end.
BR
/David
Hi again,
@adrilang 2On normal TV like freeview select that option even if not set up." Could you elaborate on this? Freeview that some UK platform, should I use this when adding the box via universal remote?
Anyways thanks a lot for the tips. Will keep on and make update if I get all to work. Need to take a soccer break now
BR
/David
ok will keep trying.
just switched hdmi port, the TV did was not able to recognize the GTV box, i left it unrecognized then the one remote could be used, everything worked except the channel up/down
then tried to add the GTV via universal remote as Formuler box, everything stopped to work, strange.
BR
/David
tried that multiple times
Anyways, if it work for you I will keep on trying, maybe resetting TV, leave it unplugged, switching HDMI port etc will get the one remote working who knows.
/David
yes Anynet+ is activated(also have a Samsung soundbar that is controlled by same remote).
Strange that you can operate the GTV but not me. I have a Samsung NU8000 model TV, but I guess the universal remote provider list should be the same on all Samsung TVs. Maybe one could try with some other provider in TV list and get it to work that way.
So GTV is identical to other Formuler boxes and should acknowledge the commands from the Samsung TV if provider Formuler is selected?
BR
/David
ok, CEC etc is fine. I set universal remote to Formuler that can be found in TV list of providers but it does not work with the GTV box, it works with my previous Formuler box if I switch to that one.
So I guess either something needs to be changed in GTV box SW or Samsung need to add new support for GTV box(NEVER going to happen).
I even tried to pair the Samsung BT remote to the GTV box, it pairs but cannot operate the box...
Well if anyone finds a workaround please share it
The small Samsung remote is really nice to have when lying in darkness with its few and cleaver operating buttons..Thanks
/David
Hi SAM,
well the question was not really about the BT1 remote rather why the GTV box dont respond(changing channels etc) when I am using my regular Samsung smart tv remote like previous Formuler boxes did?
/David
got a GTV yesterday, upgraded from some old Z7 model. Nice upgrade all though with some issues here ans there!
The new BT remote is fine, but for casual use I would like to be able to use my Samsung remote as on could for the Z7(I think for all previous Formuler models), changing channels, power everything down/up in one go etc(actually powering down works..). Is there anything that can be done that I have missed? Or do we just have to wait for this to be fixed somehow in upcoming upgrades?
Thanks and BR
/David
