Can anyone help when im pressing any button on formuler z11 pro the remote is flashing orange and working intermittently I’ve replaced batteries and rebooted box aswell any other suggestions
Posts by Dpritchard1988
Looks like im not the only one then if anyone finds a fix please post
Thats not worked either mate but the reset has put google voice typing selected back on when i did factory reset
i enter the pin click ok nothing come up
nothing is connected to box rebooted uninstalled mol3 and reinstalled in aswell just incase cant do factory reset either
Ive tried all then options turnt one off turnt one on turnt both off still dont get nothing
Photos as requested
ive cleared cache data and even uninstalled mol 3 and retried no luck
any help would be much appreciated when entering portal details no keyboard comes up and when trying to do factory reset i enter pin but no other options after that
When you pause dd atmos 4k and start again audio out of sync.
have you downloaded audio optimizer and load that usually does the trick
Wont let me download it iptv download error
Yes no matter what you do it just boot up the same thing everytime
Ive done wipe data and factory reset no option for fresh no matter what i do just goes back to same page
Done wipe date factory reset but no set refresh
I upgraded from z8 to z10 pro max,the z10 is alot faster than the previous gen,portals load alot quicker and the ui is alot more smoother
i would of stuck with z8 i did the same and z10 is pain full of bugs and issues z8 was flawless
Ive got a gtv i havent used in long while but when i boot box up comes up with this no matter what i do it just keeps coming back to this page any help appreciated
Evening can anyone help ive been having issues for weeks now formuler z10 pro max and on z10se where the 3 lines on controller dont respond with box i have replaced batterys and the only thing what makes it work is going into apps force stopping mytvonline clear cache and reboot box this is happening more and more …also some of the channels keep disappearing the catergory is there but it says no channels again a reboot on the box brings them back i feel like im constantly rebooting box any help is much appreciated and this isnt just me cause i have friends who are having same issue
Service works fine on other models absolutely fine i have done master reset still same
Try removing some groups what you dont use,some Providers have so many groups i removed half the ones i dont use and makes so much difference with epg loading times
getting same here with neo
getting same on neo aswell
I am sorry if it was answered before but i cannot find in forum.
What can made an error 7-400 in a Z-Alpha that worked until now ?
Account was cleared, remade, nothing always same error
Recently been having issues with mytvonline app been watching live tv and then when i want to bring up menu the remote dont do nothing wont bring up vod series connections etc ….only way to fix this is to force stop app and clear cache i have tried factory reset , uninstalling my tv online app and redownloding which works fine for couple of days then returns back to same probelm any suggest or is this a bug within the box which devolpers are aware of and waiting for hotfix update
What code are you using for unlinked ??
Nobody buys these boxes for netflix or other apps 😂😂 is that why everyone is mentioning its not working not being funny but when you pay top money for a box which is google android based but yet the most common apps which are used are not compatible then yeah its a joke in my eyes ...who wants to have to mess around side loading apps not even a market available on theses compared to the z8 which i have also ...like i said in previous post if they had these apps working im sure it would be advantage i reackonmend this box to everyone but the downfall to people actually getting them is because of the lack of support apps when they can pay alot less for a box or stick and have the most common apps working
Theses boxing are becoming so unpredictable with other apps disney netflix itv hub bbc iplayer nothing is straight forward with apps not being compatible sort it out formuler a £20 firestick lite is more compatible with apps putting all reasources into bringing out the next model but still cant get the basic apps what everyone wants these devices for
Ive had the full collection on formuler boxes the z7 z8 alpha z8pro neo but recieved my gtv yesterday afternoon and it is back in the box with the z8 plugged back......gtv has so many bugs even with all the upadates currently available nothing was running smoothly google play store apps like itv hub bbc iplayer dont work on device so untill they improve it with updates etc i wouldnt touch it .... the words from the mrs whats this crap you have brought plug the old box in 😂
