Thank you so much ... your the best ![]()
Posts by speedyracer86
Sorry but not exactly, otherwise i would tell you instantly. I think that working version of stalker is not official, otherwise would all versions work with this feature.
How ever, someone will contact you and give you informations.
That would be wonderful if someone can reach out to me or guide me please
It was already written that trailers works only with one specific version from stalker, we don´t know which one. This must your provider find out.
For now only on XC Api and m3u. If stalker implement this feature into own protocol then it will also work with MOL2.
do you know which specific version of stalkerware works so i can tell my provider.. they are currently using 5.6.1
This just connects your device to XC portal or Mac Portal... which i am aware of but doesnt shed the light of what needs to be done on provider's end in order to make sure we can get this show cased (trailer)
i dont have a gtv box but i do have z8 and alpha both of them wont show trailer using mac based portal
Connect with xc api, it will not work with mac portal.
My Provider only has stalker ware server... but if there is a way for him to connect via XC api let me know the documentation i can definetly flip it to them
HI
I am using a MAC based portal... i am unable to see TRAILER on the VOD portal
I did check with provider and he mentioned that he is using TMDB api to pull the movie details but for some reason its not showing.. is there a manual or a process that needs to be done on my box or the provider server in order to facilitate this issue ? -
I dont see the trailer on the VOD on my current server... PROVIDER is willing to cooperate and update.. he is using stalker based (MAC)
how can they connect to the api for stalkerware(Infomir) for them to get that done.... ? if you can guide or send me a documentation that would really help
what does the provider need to do in order to enable this feature... this is for mac based portal
