Thanks, I tried that but nothing there
Posts by Tagsway
Hi
On mine I have no check for config update in storage/reset
I have z8 pro
Any help be great thanks
I have a z8 pro which has been locked with a custom config code so it’s tied to a supplier, is there a way to remove this please, software reset ect don’t work
Hi
I use username password whichbis coded to my supplier, vod and series won’t play just get a spinning circle
Same with or without external player
Any help be great
Hi, I have just started selling neo and have 2 customers with a spinning wheel when trying to access vod from my supplier, we are username locked to our server, any ideas please
Ok thank you for your help
Hi
Thanks for input, the box was brand new, unopened
I have done a factory reset and it is the same
Good morning
I bought the box new without any subscription on it, is there a way to reset it?
Trying to put screenshot but won’t let me
I’ve just got a z8 pro but in connections it has no option to add portal? It has portal nickname option, any help appreciated
