Posts by Kris-B
    I juste linked my NAS (Synology) to the Z10. That's work, I can record.
    I have 4 questions :
    - Where can I find the recorded program (and manager the recording) ? I searched in the menu but didn't find or I missed it
    - I was on a channel, I started to record but when I tried to change channel I receveid a message 'record in progress', It's not possible to record a program and watch another one ?
    - Is there a way to schedule a recording based on the program name when the air hour is different depending day ?
    - Is there a way to record a channel from 12am to 16am each day ?
    Thanks,
    Download the version from the Market app located on the home screen.
    Do not update the Netflix app when prompted. Just sign-in.
    Enable mouse mode on your remote to use the app.
    You can map the mouse cursor function to one of your hotkeys from the Formuler Remote app.
    Thanks a lot :smiling_face:
    About the mapping.
    1. Selected the model of my remote
    2. In the RCU Kotkeys menu, I selected app to assign
    3. I don't see any "mouse cursor", I see netflix, Spotify, ... but not this function.
    Strangly I can't exit the RCU Hotkey menu to assign other keys like ".." when I exit the application (via home or back) and I relauch it, I am still at the same place in the remote configuration.
    Any idea?
    Thanks,
    I just replaced my NVidia Shield by a Z10 Pro Max.
    I'd like have as on the NVidia have Netflix on the formuler, how can I do it ?
    Thanks,
    Update : I installed Downloader and then AptoideTV and then Netflix but any version works on this device :frowning_face:
    From my PC I was able to cast some streaming website (like uptostream) to my Shield. How can I do the some for Formuler ?
    Thanks,
    Update : I installed 'AirScreen' that's work, is it the best solution ?
