Change EPG mode from normalMode to UTC Mode then your EPG will populate
Posts by $$Ragu$$
I have purchased 2 GTV's and both are connected by ethernet and about every hour I get 1-2 messages popup ethernet not connected . Also i standby some times yes sometimes no standby so I'm restarting from boot Why is this happening. Also yes running latest OS & Firmware.
Anyone got any ideas?
I have actually found the opposite when I use the wifi my sip gives me about 150 mbps down but with SurfShark app set to fastest connection I can get 280mbps so that's good speed for streaming
Display More
Installed ExpressVPN on my Formuler Z11 pro max.
The internet works fine but Mytvonline 3 just show a black screen and then a text saying "servererror http 456. Contact your internet provider"
Talked to internet provider and there are no block from there end.
Talked to ExpressVPN and they don't have any solution to the problem.
Tried to connect to several different countries with ExpressVPN, but same black screen on mytvonline 3. The internet works fine like Google and YouTube.
The only country that works with Mytvonline 3 is Sweden.
But i want to connect to a Us server.
Anyone with advice how to fix this?
I would ask your provider to either put the line on VPN or to Put on AUTO and it will work, Also I have had similar issue where provider would not load but after a box restart service would operate like normal which I found weird, its all about troubleshooting trying different things my friend..
SAM hopefully it will be sooner than later it is a great app I had the chance to try it out on cheap android phone worked great awesome but as I use Apple phone for everyday use sure would be awesome for an IOS version of the app , making you guys the best IPTV innovators in the world which you pretty much are LOL
That would be a great update to consider SAM because it would;d be a pain in the butt to input 2-services on 3 different boxes . would be nice to get 1 box setup with all the services and preferences then create a backup and restore to other boxes that are using same OS and firmware... Just like TiviMate app does....
It is possible to watch two channels at the same time.
Why is there not the same possibility to record two channels at the same time?Well i can record 3 channels and watch a 4th. because I have a 5 device connection to servers. ( also I have 3 different servers in use at one time)
Sam thats not really a good option for restoring, That means I will have to have 4 backups for the 4 formuler's I have and have to input all 5 IPTV servers on each box , to me thats antiquated and dumb. You should be able to create 1 backup and restore to every box you have ,thats a big time saver.. The TiviMate app allows 1 backup of all your favourites, settings, options and restore to all Tivimate Installs
Hello I have successfully created a backup on 1 Z11 Pro Max to a usb I assume it backs up everything all the connections ,favorites ,etc, and I inserted the usb in my 2nd Z11 ProMax hoping to do a store of the successful backup on box 1 it fails to restore . Pain in the butt having to install everything and start from scratch on box 2
so why is it I only see 1 portal on my epg where are the others??
