No Live-tv or VOD with ExpressVPN
  • Installed ExpressVPN on my Formuler Z11 pro max.
    The internet works fine but Mytvonline 3 just show a black screen and then a text saying "servererror http 456. Contact your internet provider"
    Talked to internet provider and there are no block from there end.
    Talked to ExpressVPN and they don't have any solution to the problem.
    Tried to connect to several different countries with ExpressVPN, but same black screen on mytvonline 3. The internet works fine like Google and YouTube.
    The only country that works with Mytvonline 3 is Sweden.
    But i want to connect to a Us server.
    Anyone with advice how to fix this? :thinking_face:
  • Ask provider to set your Subscription to a vpn.
    that they change the country from sweden to vpn if possible.
  • I would ask your provider to either put the line on VPN or to Put on AUTO and it will work, Also I have had similar issue where provider would not load but after a box restart service would operate like normal which I found weird, its all about troubleshooting trying different things my friend..
  • If your service is "stalker" MAC connection, drop the VPN. Many (most?) "stalker" services fail over VPN.
    Cheers!
    :smiling_face_with_sunglasses:
