Z12
UK
Hard Wired
No External Devices
Reboots happening often
Posts by Bodmedia
I bought 3 of these boxes on release, the constant reboots are starting to really annoy me now, please create a fix
Try changing media player
is it possible to add “All” category in Movies and Series
Far easier for searching MOL2 was perfect for this
Please consider this
Ahh content loads straight away for me, just no option to arrange it
Go to Newly Added and just let it load for a couple of minutes worked for me.
let what load? There is no option to make the newest stuff first, done the beta update, content refresh, the newest stuff is still at the end and now way to filter it
Please check after updating to the new version and refreshing portal.
Content manager > Data sync > Contents Data > Refresh
Does nothing for me
Please fix VOD>Newly Added>Sort by newest first
In VOD/Series, newly added VOD is displayed by default or can be set using the sorting function.
Please check again or compare with MYTVOnline2
I am on about the section called NEWLY ADDED, this is not sorted by newest first, which is a shame as you need to scroll right to the end to see newest stuff which is plain stupid
I only have 1 issue with the new box
VOD and Series (Newly Added) aren't sorted by the newest first which is rather frustrating
can this be fixed?
