OK, I get it. I didn’t like the new remote so I in the Bluetooth I associated the previous remote. Now that I want to use again the new remote you have to disconnect the previous. So now the new remote is immediately connected.
Posts by obep198
Yes, it’s connected via Bluetooth it appears disconnected in the remote app so there’s nothing I can do there. I get only basic functions.
Hi, how can I connect again my remote control it’s been disconnected and I don’t see connected in the remote app. It’s connected via Bluetooth settings, but not in the app. Is that normal? Tkz
Hi why XCAPI is not similar on Epg as Mac protocol on that matter ? Should that not be fixed ?
Most Mol3 users complain about the "No information " situation in live tv.
Not everyone is keen and trained to erase cache and update manually. Surprised that no one here complain about it anymore... Does it mean most of users don't use xcapi on MOL3 ?
Hi, We are one year later the announcement of the Z11 Pro Max. I've enjoyed mine a lot switching from a Z8.
I'm wondering, those last years every year a new box was out.
Is there something planned soon ? Z12 pro max ?
Any rumours .. ?
Many regards,
O
Hi how could I change the set up from a Z11 Pro Max from distance ? If both are connected to the internet is there a way to do that ? Tkz
Yes they are all the same. But is recognize now within the Google TV App. I don't understand. I did not change anything !!! So it' s okay.
Stil my Logitec K380 isn't recognised. I don't care I took an mx keyboard and it's all fine.
I have no clue how it happend but it's ok for me. Ticket can be closed. Many Regards, Xavier
Ok I’ll recheck all for tomorrow. Tkz
Yes my mistake, I mean Google tv App instead of Android TV App. So we speak about the same.
Hi Everyone
I have freshly opened receivers Z11 Pro max (V3) that are not working as before.
1/ I can’t pair my Logitech K380 keyboard via Bluetooth anymore. While on other Z11 pro max (V2 or V3) it works flawlessly.
2/ I can't use my iPhone (paired) with the Android TV App anymore. It just doesn't appear in the list of the App to connect. Although It works flawlessly only on older Z11 Pro max (V2)
All are in the same network - same update/patch - nothing external has changed.
What should I do ? Thanks many regards, O.
HI Agaton Sax thanks I bought both. I'm gonna test it soon.
OK many thanks I bought an inverter to make a test. I'll give feedback.
Hi everyone can someone give me a response ? Many regards
Hi everyone, does someone know if it’s possible to plug a z11 pro max in a motor home via the cigarette lighter ? This with a Cigarette lighter adapter cable, 12V DC 5.5mm x 2.1mm car cigarette lighter power cord ? Instead of the given in the box 220v power adapter? Many regards!
ok very interesting. Thank you !
Thank you for your answer. I've tried, I didn't saw any difference. Maybe I'm wrong. But the tuto is working.
Also, multi connection is not allowed most of the time from what I heard. Or how should I understand it ? Tv and App on the same time for instance ?
Hi thank you for this tutorial. I still don't understand the advantage between the Mac portal (/c) and XC API ? Can someone explain me the use ? As I understand it would be for security usage ? What are the real benefits ?
Tkz
