Hi Everyone ![]()
I have freshly opened receivers Z11 Pro max (V3) that are not working as before. ![]()
1/ I can’t pair my Logitech K380 keyboard via Bluetooth anymore. While on other Z11 pro max (V2 or V3) it works flawlessly.
2/ I can't use my iPhone (paired) with the Android TV App anymore. It just doesn't appear in the list of the App to connect. Although It works flawlessly only on older Z11 Pro max (V2)
All are in the same network - same update/patch - nothing external has changed.
What should I do ? Thanks many regards, O.
