Hello everyone,
I received this morning from a client, a Formulate Z Prime blocked on the current Android installation.
Hello everyone,
I can not do a reset. How can I proceed?
For your information, I received a tutorial by email but without success.
Tutorial:
#. Manual Recovery
1. In USB root
2. Create new txt file
3. rename it to _recovery_facinit
. without file extension(.txt should be removed) / it should be only "_recovery_facinit"
4. insert USB in Z Prime
5. disconnect power and power on again
6.
"!!! at the same time(important) !!!" , press CH UP on RCU
continuously. . click CH UP button continuously,, clik clik clik clik
...... right after plug in.
7. Android update animation will appear. (Stop pressing CH UP button now)
8. it will factory reset with Android Logo if it works.
A. If you don't see "android logo" and box boots like normal situation, there must be something wrong.
(Please retry. maybe you can click CH up button before plug in the power)
B. If you see "Android logo" with ERROR message, the box cannot be reset with manual factory and needs to be repaired.
* “_recovery_facinit” file will be deleted from the USB once it is used correctly for one receiver.
To use for another receiver, you may want to create the file again.
Thank you for your help
