It's several months since your problem but over the last few days I've been experiencing the same problem with most (but not all) TV series not playing. Just hangs and then says failed. I have a Z11 pro 4k box with TVonline3 and have refreshed the source many times, both via the source and via the box. Anyone having the same problem?
Posts by georgio
Thanks Henkie but I have tried that and it isn't really the issue. I think RZstriper may be closer to the issue. I've seem to have had this problem more when I have set more than one recording for different times which are well apart but in the same evening or early morning. I don't know why it should be though. Any other ideas would be gratefully received
No. The reason is that the HDD had always worked well when formatted by my previous Z8 formuler box. and since reformatting with my Z11, it works fine as a recording storage when I use live recording. I have today also scheduled a recording by simply selecting it from the epg, using the record button on the remote. This worked fine. When the problem is happening, what I am getting is, the recording is shown in the log as recorded but also in the ended log says 0s. If I go into recordings from the main menu, each recording shows the information about the programme recorded, but no image. When I try to run the recording, it just says, error try later, but never works. So it appears to me that the epg isn't communicating correctly with the recording software properly, if left for several hours before it should activate? Any thoughts?
I am having all the same issues but I think its all to do with settings or the software itself. I an saving to a 500gb hard drive and recording without problem if I hit the record button on the remote whilst watching something. The problem arises only when I try to schedule a recording. I have tried leaving the box on standy, and being left fully on, on the same channel that I wish to watch, or allowing the box to switch to the correct channel at the time of scheduled recording. It has worked occasionally but lately it seems not to. I unfortunately have no idea why but I am pretty sure it is not a problem appertaining to the type of storage used. Can someone help?
