I returned mine, to many bugs.
Posts by hawkeye
Does the remote have a mouse button?
Difficult to answer unless you have a crystal ball,if it goes like the z11 it may take up to 1-1.5 years of updates to get everything right and stable.
However,considering the quick FW update and the already announced future updates,i believe max energy of devs, is put in new ultra and things may advance much quicker
Your telling me that a new box won't be fully fixed for 1/1.5 years? That's totally unacceptable lol so it will be fixed just in time for new hardware being released ?
Any ETA for next rollout of update?
Will the blocking of sideloading apps be a problem for this box? My understanding is only certified andriod/Google boxes are going to be hit
I can't understand how they havent implemented a new chipset.
its blown my brain. But...... the z11 pro max was a good box, unfortunately I think formular have missed a trick beings as 🍎 are releasing their new box very soon
You can set up a hotkey for the mouse cursor via Formuler Remote app
So no physical button like on the z11 pro max remote?
Can someone do me a favour if they have the bt voice remote, can you try youtube with the voice search and see if you get a blank screen? Everytime I go to use the voice search my screen goes blank and the only way to get it back on is to restart the box (z11 pro max) if someone could check I would really appreciate it
Never use a free vpn, also choose one that doesn't keep logs. The best vpns are
Express vpn
Nord vpn
Surfshark
P.i.a
The 1st three listed are not in a 5/14 eyes country which is good as there not obligated to give up anyones information nor do they keep logs
PIA is in a 5 eyes country but they also don't keep logs meaning they don't store any ip information of its customers.
Anyone got any ideas why screen goes black when using voice control on any app which has this? Plex tivimate ect... with voice search the screen just goes black and have to turn off box and back on to get picture back, I'm using the voice remote for z11 pro max and never had any issues with voice control until last week, I'm not sure what's wrong with it?? I can type search but as soon as I choose the microphone icon the screen just goes black
I'm using the Bluetooth Voice Remote from formula gtv bt1
Never had any issues before with it so not sure what's happened
Seems to be happening on all apps that have a voice search screen just goes off and have to turn box on and off
Hi has anyone got any issues when using plex and tivimate search tool, basically when trying to use the voice search, the screen just goes black and you have to turn z11 pro max off and back on to get the screen back on, any help would be appreciated.
That's exactly what it is, looks like your provider has ip locked you, speak to them and let them know your using vpn👍🏻
Hello everyone I'm just wondering if anyone has dstv on their box?
Everytime I sideload it, it says only available on certified Google device, does anyone know a workaround for this?
Only seems to be a problem with this app if anyone could help that would be much appreciated.
I would stay away from nord for the time being, they have alot of connection problems at the moment, express vpn and surfshark are really good
Hello everyone, I'm also having this problem, is there any new updates on the matter? Thanks
