1. did you try updating the z11 to the beta 11.2.2?
2. does your app allow using an external player?
I have the beta version on my box.
2 the app uses vlc, but i cant select on the app to use vlc
1. is there any decoder option on the app?
try switching if present.
2. you can also report the issue to the developer of your app to be resolve in a future update.
3. alternatively you can try another iptv client like tivimate or others.
1- dont have any option of decoder on the app
2 .- i have reported, but they say everything is ok with the app, the weird is that the same app works good of z8 and z10 without delay, and in smatrphone works perfectly.
3 - Im from Portugal my service has to have portuguese channels, vod with subs, and series with subs
some iptv client have audio offset look for the setting in your app and adjust as required.
I can't give you direct instruction because don't know which app you are using.
The name of the IPTV client is Android TV app, i think its a specific app from the provider.
I've searched in the definitions or adjusts but i dont see anything about audio or sound.
This app only uses username and password, dont need to enter the link of portal or m3u.
Its weird because on other boxes or smartphones works properly the same app.
Some attachments of app
The problem continues, i dont know more what to do ![]()
Set Audio only to Stereo and Surround off, test again.
SAM I have tested but not working. In mol3 works properly but in the other app to see iptv have sync delay of sound/image
This could be a problem of formuler z11 pro ?
If you can help i aprecciate
I have the same problem.
Any solution ?
I have a question I have a formuler z11 pro using IPTV with Myonlinetv3 I don't have sound and image delay problems.
However, using another app, I have a problem with sound and image delay, it does not match all channels and movies and series
This same app on my android smartphone has no delay problems, which leads me to believe that the problem is with the box
I already installed VLC and Audio Optimizer but the problem persists only in the app
Anyone with a formuler that can help me?
