I'm sure I used to be able to pause live TV, but this doesn't seem to work anymore. I'm not sure if it is connected to the summertime catchup problem. I think I used to be able to do this (with an SD card or USB mem stick). I've tried different memory cards and reformatted in different ways but it doesn't work. Is pausing live TV a function?
Posts by JDG
Hi Sam. I have a Z11 Max Pro and have the same catchup problem. I think it is a MOL3 issue, not a Z11 issue, as I have now installed the MOL android app on the Z11as a work around and catch up is fine on that with the exactly same provider. It is XCAPI if that is relevant. So please get MOL3 fixed as it is better than the Android free MOL. Thanks
I agree with the last couple of posts. I tried my provider with another app, and there was no problem with catchup.
I've still got the same problem (catchup one hour out); and have done all the suggestions, rebooting, checking time using manual and network, reloading provider etc, but still has the same problem. Using XCAPI.
I seem to recall there were EPG time problems a while ago which was eventually cured with a software update.
Anything else I can try?
