Posts by TDA
@JR
Please do not recommend users for such and other issues (that can be fixed on forum) to open ticket, forum is first instance and if the issue can not be solved then only staff`s recommend ticket. Thank you for understanding!
Please do factory reset, after that it should work.
If not, click in home menu on network icon and in next menu under IP -> dhcp, reboot the box once.
Factory Reset worked. Thanks.
Was hoping I didn't have to do it. lol
if other devices work except the formuler z10(after applying the last update) and you already try a power cycle(unplug the box for 1minute and power back on) and uninstall all third party apps.
you can try opening a support ticket using the link below but first you can try factory reset if you wish or wait for other forum member to provide solution.
I did on Friday. Thanks for the help either way.
confirm on formuler unit(settings>network and internet) that:
1. ip settings=dhcp
2. private dns=auto
3. ipv6=try with off if on
4. proxy=nun
5. hotspot=off
6. vpn=try off if on.
All have been set to what you have up. Nothing. I don't get how I can get video on the box, but everything else is cut off. I have tivimate working without a problem on my Fire TV box if it matters.
Got the same issue as someone else here ! Can’t connetc to Wi-Fi after this update!
I have problems too with internet since the update. It says I have a "Limited Connection" in the Wifi settings. I'm using Tivimate and I still have video, but no updated guide and no other apps on the box have access to the internet.
