Check log... 00000016C2017 i have the same problem
Posts by svennes
All the suddenly mol3 just shut down (restarting) ...Anybody else has the same problem? ...it goes back to homescreen.
Did unistall and install app again and worked since i last posted but today it started again!
Cant uninstall/reinstall all the time!!
Junk fw or box? It did start with latest fw update.
No usb connected!
Sent logs
Tracking :00000016C2017
Losing wifi from time to time with latest update!
Update icon is gone! So i have to go to settings/apps/system update to check if there is a new update.
Vod problem still exist! But it often fixes it self if you just wait.
Sound is gone so i have to use bluetooth to soundbar and then everytime i put it on i have to disable/enable bluetooth to get ut to work again.
Box seems to get worse with every update!
Still getting failed to load VOD data at random times! So not fixed 😜
Noticed yesterday if you shutdown and open app couple of times the covers are back (maybe just luck?) ..Updating doesent work for me.
Sent log C9530B
No previews on vod and vods not working att all atm...Sometimes works after refresh of the providers but previews and vod problem has been like this for almost two weeks..using latest veta now and same
Same problem here . Been like this for some days. Two providers and vod not working. Doesent help to update. Im in Sweden.
