He cant do that. Its no possible he says
Posts by adde34
Hi
Is it possible to sort groups alphabetically on formuler z11 pro max, groups that are on the left side not channels?
That
His question is what connection protocol is in use either MAC (Stalker),XC api with Portal username and password or m3u playlist (read more in Article section "How to connect.........")
Before you do a reinstall mol3,dont forget to make a backup<you can reinstall from Formuler Market (Green app with trolley)
It was XC api. I just reinstalled Mytvonline3 so we'll see if that helps
Now you ask too many questions. I'm not an advanced user unfortunately. It's on all the time because I always use it. Haven't received any updates since April. I only have 1 portal added. I haven't reinstalled MOL3. If I uninstall it where can I download it again?
More Info s please. Which Protocol is in use, which power Mode, Power off or Standby, how much Portals etc.
Did you try with MOL3 reinstall?
I use it every day and the last update I got was in april. I don't get any updates for it. I don't know why it started behaving like this
When I restart my z11 pro max it takes 3-4 minutes for mytvonline to start. Then I noticed that my channels stop working lately. I have to take out the power cable and plug it back in for the channels to work.
What could be the cause?
Thats a problem. Old tv 😒
Hi
Has anyone managed to install Netflix on the Z10 pro max?
Hi everyone
How long did it take for you to receive formuler after Peter emailed you? I emailed him back but no reply
