La mejor actualización por 2 años.
El epg ahora funciona muy bien.
Solo necesita actualizar mytvonline 2.
Le pregunto, por favor.
Posts by poli
When you do a channel search for the first time you should get a message to install the audio codecs
did you install them? -
I can not comment on the z7 +
I have the turbo 4k s and I can assure you that it is a great purchase -
It does not work 100 per cent but as I said before we are on the right track
Now if the epg works, we're on the right track.
My provider is movistar +
the egr works frankly wrong
I hope that soon the problem will be solved
It is very annoying not to have information about the programs
(Movistar + / Astra 19E) -
Ok, I'm glad you solved it
Try to update TP
Hello neighbor
test with yellow button and select audio -
It also happened to me several times and I solve it by removing the electric current
ok Sam.
We will have patience. -
there are times that it loads the information instantly.
and other times it never loads the information.
What could be the problem. -
if there is any way to configure the epg
please I need the information
in the channels of Spain does not work correctly
once it shows the information and other times it does not show it
any ideas? -
Hello
there is no way for the epg to work
does not show information of the channels
the problem is not solved with any update
I think that it is time for formulary to do something or to provide us with a plugin for this problem -
Hi, I've been with this problem for a few days
the initiator is blocked and I have to de-plug the box so that it works again
the firmware is 1.5.0 -
hola llevo unos días con este problema
el iniciador se bloquea y tengo que decenchufar la caja para que vuelva a funcionar
el firmware es 1.5.0 -
Hello
they could explain the complete method to load a lamedb list
