the keyboar doesnt pop up. so i cat press return to confirm pin
Posts by theokerstens
First it booted, then i got into VOD to search someting, i saw there was no keyboard coming so i rebooted the entire divice. Now MOL3 doesn't start.
So i thought of reinstalilng it by market but maket closes right after i start it.How do iproceed to fix it? Don't you guys have apk's i can adb?
EDIT: i cleared cache of both apps
EDIT2: Now i deleted mol3 and did software update. It sees an update but after i start the update, the process craches
EDIT3: i sended you the logs (16:57 utc+2)
EDI4: lots of these errors:
09-24 17:37:16.111 10025 10049 E AndroidRuntime: at com.google.android.gms.chimera.container.DynamiteLoaderImpl.<init>(:com.google.android.gms@[email protected] (180306-806001533):32)
09-24 17:37:16.114 10025 10049 E AndroidRuntime: at com.google.android.gms.chimera.container.DynamiteLoaderImpl.<init>(:com.google.android.gms@[email protected] (180306-806001533):32)
09-24 17:37:16.114 10025 10049 E AndroidR -
the provider gave me another link. now it works
Just run the commands. 12 packages where succesfully removed at my box
Guys,
i Bought 3 z11 pro maxxes.
I have the same problem. error 1002 when loggin in to portal. m3u works fine.
I just checked another iptv provider and that woked fine with portal
The portal not working is on a iptv reseller which uses **** as their server.
Does somebody has a clue to connect to portal with *****??
Read the @ as an a. forum blocks the word
