Display MoreZ8 have 1Gig Ethernet and not 100 Mbit! Please check again
Networking:
2.4G / 5.0G Dual-band - Dual Antenna
Gigabit Ethernet 10/100/1000M
Give your Box static ip over router and Box, this could help to increase the speed + use cloudflare as DNS Server for faster resolve.
If VPN is in use, then it`s clear. VPN reduces the speed extreme.
Yes, you did overexcited it and thread is now broken. You will need new from shop if Wifi doesn`t work correctly. In most cases this can be fixed with tape etc.
May I be able to fix the broke wifi or do i have to get a new box?
It seems that the problem is the splits from my ISP to my living room because if i take a cable from the router directly to the box i get over 300 mbits, similar to the speed i get on my pc. So, its just the way it is ![]()
