Posts by Miro15
    I just checked: My Tv online manage to change the frame rate, so indeed if you basically use only with this program, there's no problem. Once you go back to main menu and use something else without AFR, I have to do it manually.
    Once again is annoying, if you use the box with some other apps, most of the users probably don't have any issues, assuming they use mainly My Tv online.
    I cannot reproduce the problem.
    With standby and or power off the screen resolution 4k 1080p still saved.
    Wait for a fix/update. Maby more people has your problem as well.
    Use power off modus so long.
    Yes, I will use power off. But the problem is there. Try to set resolution, different than auto and not using My Tv online. Go to sleep mode and after about half an hour or more, resolution is changed to Auto. This is my scenario and once again is general issue, probably people in countries where 60p is a norm don't have any problem, and people who are using the device with my TV online only, due the AFR build into the program, are okay. There is no AFR in general settings, I believe on Android 12 was implemented... Anyway I use different devices and the Z11 pro max is the first one, which is not keeping my screen resolution preferences. I like the device, but probably would be forced to switch back to something else. Maybe different model don't have this behaviour....
    When the TV stream is 1080p 50hz, then my TV looks much better at 4k50hz . I guess in countries where 30/60 Hz is standaard, there will be not a problem. In in my case ( and I am sure also apply for other EU customers) when the box switch to 4k60hz, picture is stuttering. Anyway I hope is possible to fix it. I did try everything, all HDMI ports, different cabels, hard reset, soft reset, HDR off, HDMI CEC off , etc.... Will have to wait and see, I am sure is not a big deal to fix, as any other device I have tried don't show such behavior.
    P.S. I agree that using My Tv online with AFR, probably is not a problem. But watching with provider's app, without AFR, then I prefer to keep the resolution I chose
    I have since few days Z11 pro max and experience exactly the same problem. Have tried everything wich was suggested on the forum, also from other threads, some time ago, but no luck to keep is at 4k 50hz.
    The only way I found is to use shut down and not sleep option. Then the resolution stay as desired, but is takes time and autostart app not working.
    In my case the resolution changes after about half an hour in sleep mode. Anyway every morning starts again on auto 4k 60hz. I hope there will be some solution, because for the rest is very nice device, but I tried different boxes and never had this problem before.
