Posts by Sterner
SHL
Swedish Hockey League would be nice!
I have the same
When i hook my z12 to my Marantz Sr7800 i have a buzzing sound (groundnoice). If i check out surrond in the settings it dissapere. Also if i choose passthrough it will be gone.
The Z8 with the same connection never had that bussingsound. If i hook it up into the bedroom to the tv and the soundbar it will sound go all time.
When I go to the settings, I can see that it is disabled, but when I enable it, nothing happens.
A simple second restart solves the problem.Exactly like my wifitrouble.
I bought a S12 for a couple of days ago!
And my box is also random reboots 2-3 times per day using MOL3. Even sometimes using youtube..
And another fail is when i self choose to reboot the box.Then im out of internet. Even if i toogle on the wifi it does not found any wifi.But if i reboot it again then the wifi will be there. And that is always the same syndrome when i want to reboot the system. I takes 2 reboots for the wifi to be there.
But if i instead chose to shut the box down and start it again,then the wifi is always there.
The box and apps are updated.And i havent done a factory reset.
I am in europe and have a good wifi and router.
My Z8 did sometimes throw me out of series but never shut down and selfstart like this Z12.
Thanks for your work,and hope that you will fix this in an update now please!
Thanks for the ios-app.
I hope you can fix so it would be able to cast to a chromecast. Right now i dont find that solution.
