Hi, sorry for the delay in replying. I have tested refreshing manually and the problem still persists.
It is really a minor issue though, I do not want to bother you with it.
Thanks for your kind help.
It is with xc api
Thanks for your reply ! I have only one provider on my Z11, and each movie proposed in suggestion is found without any difficulty in normal search. The issues only happens when trying to open a movie/serie from the recommendation list...
Hi everyone !
Everything runs smoothly in my MOL3 except for 1 small issue, I thought I would try my luck here with you guy's. Sorry if the problem has already been posted/solved, but I could not find it.
In the VOD section, when in a movie description, I get proposed recommendations. If I select one, instead of going into the recommended movie description, I end up on the search page displaying a not found message. Same happens for all recommended movies, same goes also for the series.
Search works normally though.
Any idea on what's failing here ?
Many thanks in advance.
