Hi everyone !
Everything runs smoothly in my MOL3 except for 1 small issue, I thought I would try my luck here with you guy's. Sorry if the problem has already been posted/solved, but I could not find it.
In the VOD section, when in a movie description, I get proposed recommendations. If I select one, instead of going into the recommended movie description, I end up on the search page displaying a not found message. Same happens for all recommended movies, same goes also for the series.
Search works normally though.
Any idea on what's failing here ?
Many thanks in advance.
