Can you tell me what Nord app firmware you are using.
Posts by Lance762
I also have z12 ultra and Nord vpn,i use TCL (openVPN) and have no problems connecting or dis connecting.
I have no fancy settings - it’s literally downloaded from either playstore or the formuler App Store , login and then connect. My z11 pro max works fine doing the exact same thing
Nord vpn connects the issue is when I disconnect from the vpn server within the Nord app , press home on the remote but I still have the padlock symbol indicating the vpn is still connected. The system is then in limbo as the app indicates its ‘unprotected’ but the system indicates its connected . So I then have no connection to the internet without force stopping the Nord app
Update :
Issue remains : uninstalled nord , rebooted formuler z12 , used Google playstore - downloaded Nord 8.31.2-tv. Logged in connected to vpn server and then disconnected , app shows unprotected , system shows padlock , unable to connect to internet without force stopping Nord app. -
Ok will do and report back 👍
Hi all, currently have a formuler Z12 ultra and also the Z11 Pro Max BT1 .
When using Nord VPN on the Z12, it connects fine but when you disconnect the Nord app says you have disconnected but the padlock symbol remains - you then can’t connect to the internet . I then have to go to apps find Nord and force close /stop the app and then everything is fine .
The Z11 with the same Nord account is perfect . Anyone recommend a solution? I have done a factory reset , also made sure to use Nord from the formuler App Store.
