Posts by badmad04
    Yes, my MAC address was in Stalker mode, my portal was locked just for the provider... I had asked him for the URL, username, and password to put my MAC into XC API. He gave me the username and password but not the URL, so I used the PCAPdroid app to capture my data... That's why I thought the /c/ was part of my data.
    In any case, thank you for taking the time. I wish you a good day!
    If there was NO block or you did it removd already it's not nessesary to check for block again.
    Thank you very much :smiling_face:, thanks to you I have the EPG! After resetting, I told myself I would try modifying the URLs each time. For example, I have 'formuler.com:1234/c/'. I deleted the ' / ' at the end...
    still nothing. I thought about deleting the ' c/ ' and it worked! :grinning_squinting_face: I spent a week tinkering just to delete two letters.:grinning_squinting_face:
    Yes, I already did that at the beginning of the problem... but I can always do it again. I haven't installed anything on my Z11 box yet.
    I will come back and let you know early this evening.
    z11 pro max
    Indeed, it was probably due to the DNS. After an hour, my account is working again with my old credentials. I ran another scan with the PCAPdroid app and my old data reappeared... I removed the '/' slash, but unfortunately, I still don't have the EPG. I'll just have to wait for my second provider to expire so I can lock the portal back to my default provider to get the EPG. Thanks a lot for your time anyway!
    Hello, thank you for taking the time to help me. Now it won't connect at all... Can the provider see the connection attempts I'm making on the same box? I've been resetting it so much... My URL and password no longer work, not even on my phone where my account was already saved.
    edit ; Strange, it works again when I lock my box with the provider. I used PCAPdroid on my box to see the URL, username, and password. Everything has changed: my URL, my username, and my password. Considering I had the same URL, username, and password for 8 years, everything has changed!
    I don't understand, did the provider change the details because they saw me connecting multiple times with my credentials, or is it a bot that changes the data after detecting multiple attempts?
    Thread moved into right forum.
    not sure what you mean exactly by that.
    Delete your current portal (i guess XC Api) and create again new one but this time take into account this steps -> RE: Guides Are All "No Information" (Z11)
    Hello, first of all, thank you for replying. But my EPG issue is actually different: when I lock my portal to just my provider, I receive the EPG for the channels... But when I unlock my portal to use other accounts, I no longer get the EPG for the channels. Also, the URL ends with /c/
    But with my second provider that I enter (the temporary provider), I don't have any EPG issues.
    Hello, oh sorry, I didn't realize this wasn't the right place to post. Could you please let me know if you managed to get the EPG to show up on your end? Thanks, have a great day.
    "Hello, I have a Formuler Z11 Pro MAX. Everything was working perfectly until I unlocked the portal in the system information by entering '000000'. After doing that, I had to enter the URL, login, and password.
    Everything else works fine, but I can no longer load the EPG. I left it on the default settings. I’ve tried everything: clearing the cache, loading the EPG, and refreshing, but nothing works. In the portal settings, no date is displayed for the EPG, and when I try to force an update, it fails to load. As a result, all channels display 'No Information'. I have to go into the full EPG menu just to see the program listings."
    Oh yes, I've already cleared the caches, performed a factory reset, and all of that... but still nothing works.
    I also tried using a 5G hotspot from my phone, but it didn't work. However, on the Smart Pro app on my phone, the EPG displays correctly for all channels. Is this a problem specifically with MyTVOnline 3
