Unfortunately there is no EXIT key available in the Air Sync Remote Z app.
To get past the Screen-adjustment screen, connect a USB keyboard to your Z7+ and press the "ESC" key.
Thank you for your reply. I'll try that. Maybe a suggestion for the next update for the application could be to add that button on the application or remove the press exit key on that screen in the firmware.
