Just updated again seems to of fixed
Posts by Jake360
Posted this on Facebook page as well, Updated my s mini but sat tuner colour is now bad again, red tint appears on people’s faces, this was fixed in a previous update but seems to be back again after this latest update, think it was the Patched HDR contrast issue that fixed it last time, can this be looked at thanks
Auto update overnight would be good, I can only get open epg to work, how do you get xmltv epg to work, what’s the steps do I need to pick rytec or put a url in for epg to download
Epg for freesat Astra 28.2e Bskyb does not work on s mini
Good, android picture [lexicon]settings[/lexicon] are terrible, contrast/brightness is set stock way to high, and if you turn it down it makes your DVB TV picture bad and can't seem to calibrate it on my own tv picture [lexicon]settings[/lexicon], people's faces either have a green tint or go the other way they get red/orange patches
Thanks but did not fix my sync problem, DVB tuner needs an update
Any body else having audio sync issues on the DVB s2 tuner, I'm in uk and I have to set av output
In DVB [lexicon]settings[/lexicon] to 2160p x 60Hz NTSC to get voice to sync with picture, why is there no 2160p x 60Hz PAL, also have an issue with red/orange blotchy patches on skin tones I can't seem to calibrate out, its definitely not my TV picture [lexicon]settings[/lexicon] as I have had a mecool k1 pro with DVB S2 sat tuner and zgemma H2S running fine, IPTV picture is fine so it must be tuner related.
any advice on what DVB picture output [lexicon]settings[/lexicon], android display picture [lexicon]settings[/lexicon] you guys recommend.
thanks -
Is it possible to move/sort re-order channels once I've added them to favourites section?
thanks -
same here epg only shows whats on now and next prog
