Display MoreI have a Z10 pro max running mytvonline2, about a month ago I started getting a black screen,
The portal loads but then I get a spinning disk and it says please check your Internet connection (0) a network error has occurred.
I have an ethernet connection (via a tp link),all the other apps working fine.
I have installed Tivimate used the same portal settings it works fine, I have contacted my provider thay have sent new settings exactly the same.
The strange thing is if I press the guide button with mytvonline2 it shows me all the programs and times thay are on, looks like the epg is loading but no picture ore sound.
I have factory reset my Z10 pro max (the same), uninstalled and reinstalled mytvonline2 ( the same no Internet connection (0) ),
I have reset my router, gone into settings made sure made sure it is set to DHCP,
Has anybody else had this problem
Hi! Never heard about UA Block??? Check it your Service, if your line/mac are restrict to UA!!! ![]()
