anybody having problems loading portals or issues using vpn with mytv online?? ![]()
Posts by Finbar1979
when i install certain streaming apps they do not show up on screen after install??
Home button
Dont realy want to use that method
is there a way to set the default record location to internal storage instead of having to use external??
i just set up my z11 pro max and very happy with it, is there any way to exit the mytv 3 app quickly like in older version??
Try first with MOL1 clearing cache.
Tryed all that mate
i am running a z7, lately i keep loosing my favourites, any solution???
i could record a program for example 3hours long, usualy wwe raw on bt sports, lately when i play it back it keeps jumping ahead by 10minutes or more, i try rewind it but it will not play the 10 that was jumped!! Also today it recorded 3hours 15minutes which is correct but would only play back 90minutes, how do i fix this??? I have done all the usual, format usb, clear cache etc...
When i go to play a program on catch up tv in epg i am getting message "cant play this video"??? Seems to be only happening after recent update
So hard to understand? From Z prime until Z7+ 5G, all Z boxes included, Z8 not included because it has own fw and sw.
Cheers mate, my error...
Answered other thread. Wait until official comes out, install and then do the factory reset and set your box fresh.
Will this solve the issue??
Official for Z Prime <> Z7+(5G) planed on 21.10.19.
I have Z7+??
Did you ever done factory reset?
Have never done a reset mate.. on a slightly different topic when is the next update due?? I tryed the beta update and now some recordings fail..
Yes i think it is provider issue
No mate, this is only happining since i got new sub few weeks ago
Did you install the beta?
Installed beta and still losing favourites
Not yet mate
Connected by mac, app version is v1.09.80-2366
I know this topic was addressed before but i keep loosing my favourites everytime i power down or exit the app, is there any work around to this or fix??
yes begining to think its provider issue
having issues with watching catch up tv on **** etc, when trying to watch a program on catch up it keeps "skipping, jumping, buffering, etc" any fix to this?? I have 25gb internet speed and watching live tv is perfect.. help..
what about menu option to "add minutes to begining/end of recordings??
i have lost a few channels recently, is this provider issue??
anyone??🤔
seems to be getting 2 problems with record lately, (1) some recordings seem to be skipping not buffering!! (2) example if i record a program for 2 hours only 1 hour +/- will playback even dough the status bar shows 2 hours!!
The problems with recordings is if the picture buffers the recording stops!! Surely there is a software fix to this!! So that even if it buffers it still records!!
i see on the new update there is a new option in settings called "epg time offset" what is this???
Getting no sound in my vod section, anyone else have this problem??
This is not the main problem it was long time open for everyone, problem is when new hundreds users install Beta and open each day tickets on Formuler support and ask why this or this not work. Beta is Beta and not official, this should be not forgotten.
Very true mate
Mite be idea in a future update to create a setting in the menu to choose default minutes added to start/end of every recording except a manaul one.. also when watching a recorded program and for some reason you stop it when you return to watch it you get a on screen message "resume"
havent checked mated, should it have??
seems to happin to cartoon hd and few others too, hope there is a fix soon..
why was the "red" beta test function removed from the update menu?? And how do we update from now??
Display More
August update
Firmware Version:
Fomuler Z/Prime/Plus/Nano : 2.8.22
Formuler Z7+/Zx : 1.2.34
FIX: Z7+/Zx Stuck in standby mode
FIX: Market > Certain apps not showing in custom markets
FIX: Launcher icons not appearing after reboot
Added discrete Power ON & Power OFF keycodes
Custom Android hostname/device name supported. Change from the system menu
Market shortcut can be deleted from the homescreen
FIX: Installer Mode > SYSPIN issue
FIX: Installer Mode > Langauge preset not working
FIX: Installer Mode > Power mode preference issue
DRIVER: Add Tenda U12 USB WiFi adapter support
Android 7 > Android Security Patch Level : April 2018
General performance enhancements, UI improvements, and bug fixes
Improved Lithuanian language translation
MYTVONLINE Version: 1.9.48 (BETA)
Teletext Subtitles supported
Manual EPG time offset. Access from the Settings menu
Xtream-Codes API portals > TV Series section supported
VOD > Continuous play option added. Press the Green hotkey to toggle
M3U > All tracks from VOD-only m3u list are parsed and used - regardless of stream file extension
M3U > Compressed xmltv EPG archives supported (.gz or .zip)
Automatically hide empty groups/categories
Added stream codec details. View from the detailed information popup window
TV Series Shortcut. Press and hold the VOD button on the remote
Remember last selected subtitle preference per channel
Improved channel icon caching
Improved EPG download performance
FIX: EPG description not displayed when using M3U + XMLTV EPG
FIX: Black subtitle font when only 1 subtitle track is available
FIX: RCU VOD hotkey while in Classic Channel list
On the recording update part can we add minutes to start/end of epg recordings??
Display More
August update
Firmware Version:
I believe so yes. That’s how he worded it in his original post. Although this could cause an issue if you have back to back recordings (on different channels), it’s a start!
Yes correct but like on the zgemma h2s units if there is "back to back" recordings the preset +/- minutes would be overwritin!
