the Z12 is connected to the soundbar
As the other user said, temporarily connect the z12 directly to the TV using the HDMI cable to check if the strange resolution behavior goes away or not.
Any suggestions?
Install and run the Memory Cleaner app from the Market and try again
I need to know how to activate the OK working as the same as from the TV remote control.
Open Formuler Remote app > Go to "Setup IR Control" and select your TV brand.
After everything is programmed, press and hold the TV/STB button at the top of the remote until the light blinks red 3 times.
Now the majority of the buttons on the remote will control your TV (including the OK button).
Press and hold the TV/STB button until it blinks 3 times again to toggle back to controlling your Formuler.
please could someone contact me to run through the process and expense please.
You can create a new ticket using the chatbot at https://support.formuler.tv to inquire about how to create your own configuration
Display Moredo you guys have a NAS, and other vpn then protonvpn or nordvpn? And can test it?
And do NAS connect at startup with the box and disconnect when the vpn is connected? Also if you splittunneling all the apps inclusive the system apps?
Can somebody with a NAS (hardwired) to the router just like me, and have another vpn provider than protonvpn and nordvpn test if the nas connect and then disconnect?
So i can find out what it is. Box or vpn.
I think already carefully the box, cause protonvpn and nordvpn disconnect nas.
Staff Can you check this please
You can try using any available 5v USB charger or USB port that supplies more than 1.5A.
For example there might be a USB port on the TV that can supply power to your mini.
Make sure you don't have any DNS apps installed/active. The key can appear when using DNS changer apps as well.
If you can't figure it out, write down the important information from mytvonline and factory reset the device.
Maybe your remote is toggled to control the TV.
What color is the light on the top of the remote when you are pressing the buttons?
Hello;
Running a Z11 Pro and MOL3. Recently the You Tube app has stopped working with a "not supported on this device" error. Prior to a few days ago it was all working fine. I have:
Any ideas on how to fix this? Thanks for any and all responses.
Try to leave the box on overnight to get the latest updates from Google automatically in the background and try again.
Also please share the following info from your device.
Youtube app version: Check from Android settings > Apps
Google Play services version: Check from Android Settings > Apps > Show system apps
While watching the ATSC live channel press the red button and make sure the correct audio track is selected.
Also, triple check that Audio Optimizer is installed and loaded.
Open the Market app on the home screen and search for Audio Optimizer. Install/Open it and click the LOAD button.
Share a photo of the codec details of the channel that has no sound.
Go to the channel and press the INFO button twice. Take a photo of the details on the screen and share it here.
If the audio format is AC4, it isn't supported.
I have a Z11 Pro Max. I want to add a custom EPG to one of my services. This service works fine using XCAPI. However, I cannot add an EPG using XCAPI, so I'm trying to connect with the provided m3u. When I I try to use m3u, I get "Code:1000"
The interesting thing is that I can enter the same m3u information on my phone using MyTVOnline+ and it works fine.
I have checked the information numerous times, cleared cache, and restarted Z11.
Any insight would be appreciated.
Triple check that the m3u URL is input correctly.
To avoid input errors, use Google TV remote on your smartphone to copy and past the URL and try again.
Also try only with the m3u URL first. Don't input the custom EPG yet.
Try to use an unfolded paper clip to press the button inside the IR extension port on the back of the device.
1 short press should move the cursor to the next position and a long-press of the button should select the current item.
The button inside the port is small and it requires some precision to press it. Aim the paperclip towards the bottom of the port when pressing.
Don't use force or you risk breaking something inside the device.
Here is a video that may help.
1. Channels have EPG events. The events can be viewed in several places: Info banner (now/next events), Channel list (now playing event), grid EPG, and single EPG. If your provider doesn't send EPG event data for a channel, it will display "no information".
Given the above context please re-explain your question.
2. Try to reduce the number of past days EPG data that is saved to see if it improves search speed. If you reduce the number of days it could take a long time for the system to complete the delete operation in the background. (Content Manager > Data Sync > Auto Update Settings > EPG data storage)
if you think heat could cause this flickering.
Never heard of this symptom before, but can't rule anything out.
If you have another TV in the home, I think you should try the Formuler on another TV for a few days to try to narrow down the source of the issue more.
Could it be heat related
Where is the Formuler box installed? Is it in an enclosed area or a place with poor ventillation?
Some things you can try to narrow down the issue:
Did you find any keyboard mappings? Or are you able to share what you found?
I'm mostly trying to find how I can change channels in MYTVOnline3 using a keyboard but down to learn other mappings.
Use the remote
Only Formuler GTV will appear in the compatibility list because all other Z models are AOSP and not Google certified devices.
HDMI output resolution is not related to "channels" resolution.
Try to use a VPN to see if the results are different.
Maybe your new iptv account is using a MAC connection?
Ask your provider for XCAPI connection (username and password) and the issue with the recordings might be solved.
Local timeshift requires a USB memory stick connected to the Formuler. If you already have a USB stick connected, try to reformat it.
Catchup depends on your iptv provider.
Make sure you're plugging the mini's HDMI cable directly into the TV without any extension cables in between.
Also, make sure you are using the USB power adapter that came with the Z mini and not one of the USB ports on the TV and try again.
With the long cable the Z8 Pro box displays the Formuler Z8 Pro logo and then black screens with the TV stating No Source found.
After the Z8 logo do you see the android text logo?
Try this:
Take the Z8 to a working TV and manually set the HDMI output resolution to 1080p60 or 1080p50. Turn off the Formuler and take it to the problematic LG TV and try to see if the problem went away.
Also when the Z8 is booting, use the TV remote to show the TV's info OSD that will show the current resolution and report your results.
Help…
I think you should revisit the display settings. They need to be changed back to the original "working settings".
If you can't remember exactly what was changed to get back to the original configuration, maybe a factory reset of the Formuler is in order.
Does the Z8pro work well on other TVs with whatever cable?
the 3 hdmi cables of the customer are in a tube behind the wall
How long is the cable that runs in the wall?
Do you know if there are any intermediary devices between the Formuler box and the TV? (HDMI Splitter, AVR, etc)
When the app DRM info woupd show that the HDCP handshake is failing, what can I do to resolve that?
The first thing I would try is to unplug the HDMI cable from the box and plug it back in so the HDMI/HDCP handshake is reinitiated. Then check the HDCP status again.
Formuler devices work perfectly fine with LG TVs, especially the Z11 Pro Max. The remote controls every setting on an LG TV, which is remarkable when compared to other universal remotes. However, Formuler does not work well with JVC TV, as there are no TV codes in the Formuler code list for JVC TV. That's something I think Formuler needs to do for their next update, as very soon more people will be using their devices due to the third-party app block on other devices.
Sometimes another brand's codes will work. Try the Atvio brand codes. (answer from Gemini)
If that doesn't work, please share an image of your remote and the product label from the back of the TV
Hello friend HDMI 1-2 transition key TV automatic off timer screen i.e. Introducing the OPTIONS key on the Sony TV Remote Introducing the arrow-up-down keys
HDMI transition key = SOURCE key: SUPPORTED on BT1
TV sleep timer button: not supported
Options key: not supported
Arrow up-down-left-right, OK key: SUPPORTED on BT1
Menu, back, home: SUPPORTED on BT1
I think you can use the MENU, OK keys and the arrow keys to accomplish 90% of what you need
Can you share the reason you prefer to use the external player over the built-in player?
Can I transfer 4-5 features of this TV to the Formuler Z11 Pro Max Bt1 remote control?
Which features do you need from the Sony remote?
Buy a Formuler device.
Change the HDMI Cable.
Change the HDMI port the Formuler is connected to on the TV.
Check video playback on the Formuler using Youtube. Select any 4K video for testing to see if the issue still exists.
Codemy z11 pro max which is connected to a denon amplifier has started to exit mytvonline3 after 4-5 minutes, it starts by going into search mode then it ends up on the home menu & it lowers all the sound at the same time on the box, not the amplifier. then it starts youtube without sound. all by itself. sometimes it starts adding rows of favorites on the home menu. I have disconnected the remote, removed the batteries & connected the control again, still the same everything started yesterday, previously it has flashed in white, one to two seconds later landed in the menu mode. if I start mytv3 again the picture is back again immediately, it can take 1-2 hours between these white flashes. but now it is worse as it behaves as I described at the beginning. does anyone have any tips.. would rather not do a factory reset, because of all the tv and films shows we have saved.
Sounds like the buttons on the remote are being pressed unintentionally.
1. Take the batteries out of the Formuler remote
2. Install the Google TV app on your phone. Open the Google TV app on your phone and use the virtual remote to control your Formuler
3. If everything is working ok with the virtual remote, check your Formuler remote for abnormalities.
