Posts by V.Rds
    Yes, It didn’t work. But actually with Kodi I didn’t find how I actually load subtitles , so I can’t really say Kodi don’t work.
    I want a simple video player, Kodi has too many things and takes a lot of time to open when used as external player.
    I found that Archos Video Player can play some... in some VoD it recognizes the subtitles and playe them, but other it doesn’t even recognize there is subtitles (But there is... and it works with built in player on MTVO.
    Hi all,
    when I try to play a 4K VOD (Mkv file format), with an external player (I want to use VLC, but I tried several to exclude that the problem was the player) subtitles don’t show.
    Weird thing is that, if I go to the subtitles selection menu, when the list of the subtitles available is piped up, the subtitles appear, but when I close the menu they disappear, this happens with every player I tried, but works fine with the build in player of MyTvOnline.
    only mkv files has this problem, with other VOD formats it works fine.
    anyone else with same problem? :thinking_face:
    Hi guys, can I make a suggestion of what be great in some future version of MYTVONLINE... Be able to mark as Favorite your Series 😉
    I hope this will be possible to do, I think a lot of user would love to have this option.
    The engineers added the drivers, but we don't have this adapter at our offices, so there was no way to test if it works or not.
    We were hoping it would just work without issues, but it seems that there needs to be some extra intervention to get the adapter to function properly.
    If you have a linux machine and can provide the lsusb output when the adapter is plugged in, it could help us narrow down the issue.
    Otherwise, we would need someone to mail us their adapter to look into it into more detail.
    thanks for your reply, and all your efforts to add this driver. I understand that you don't have a way to test it. Unfortunately I don't have any Linux to help on this ☹️
    Again, thanks a lot for your effort. It is good to know you listen your clients 😉
    I'll ask the engineers if the drivers can be added to a later firmware release.
    You Guys are AWESOME !
    I've just downloaded Beta Version 1.2.34, I saw you guys included the drivers for this wireless adapter :smiling_face:
    But,I can't get it to work :thinking_face:
    I have disable internal wireless, plug the adapter into the 2 usb port, restart a bunch of times, and I can't conect trought the adapter (never see it blink any light)
    But when I connect the USB wifi adapter, I can't enable internal Wifi (this tells me that the USB adapter is doing something, and the box is reconizing something related wit wifi is connected)
    Anything I need to do to enable the usb wifi adapter? any suggestions?
    Thank a lot for you support.
    That would be great, thank you so much.
    I'm from Portugal, I couldn't find any online store that sends one of the dreamlink adapters to Portugal. And if I find any, probably just transport cost would be higher than the adapter it self.
    Thank you
    you can't but you can purchase the W2 - 600mbps wifi adapter or the W3 - 1200 mbps wifi adapter $20 & $25
    my Z7+ came with the 600 but wanted better speed so I got the W3's
    I have tried to buy one dreamlink adapters, but I couldn't find a store that sells to Portugal ☹️
    So bought one that has one of the chipset in the compatibility list.
    I just bought this usb wifi adtapter, hopping to get a better internet conection (Tenda U12 ac1300), with the chipset RTL8812AU. But the box wont recognize the adapter :frowning_face:
    How can I enable it? Is there any way to install the drivers? Isn't the box supposed to reconize this chipset?
    Thank you for your support,
