Posts by Lucky13
    Is it possible to have a different trailer app in MOL3 than the one in the Market app? Trying to update to the latest version of SmartTube, but getting an error. Installed SmartTube manually from their site, but it's a different package name, so I can't choose my manually installed SmartTube app in MOL3, it just redirects to the version in Market.
    Should come in next mol3 update.
    Due signature was stolen from smarttube, they made a new signature and gave the smarttube app a new package name.
    I got info from F_Peter begin this year, that it should be in next mol3 update the new smarttube so you can choose the new smarttube.
    Maby you can try TizenTubeCobalt and or newpipe.
    But i thought it couldn't be choosen in mol3 (yet)
    TizenTubeCobalt:
    https://github.com/reisxd/TizenTubeCobalt/releases/download/v1.0.8/cobalt-arm.apk
    Newpipe:
    https://archive.newpipe.net/fdroid/repo/NewPipe_v0.28.4.apk
    OK, it was probably sorted wrong because it was HD only. I watched the whole movie last night for over 2 hours because it was good. Also on one of my cheap IPTV providers that doesn't have very good bandwidth without a single problem. Also tested it on my iPad over the 5G mobile network. The properties of the movie in the picture below.
    svejoh
    Well done my friend. Long time spending on testing. Mostly it's on user end or provider the problem.
    Have a nice day my friend.
    Thank you. Another thing: when I turn on the box and press the right button on the remote to go to the next app, the remote skips the app immediately to the right and goes straight to the third app. I know it’s a minor bug, but we, the Formuler family, are still waiting for improvements.
    I don't have it. Goes to the 2nd app?
    Same box, different things😂
    the things is on the box there is no indication of a custom android and i cannot find anywhere this type of player:
    What is the point of a formuler box? i saw there is prime, there is hbo, youtube, etc, the only one missing is netflix.
    SAM check this out!🙈
    Fake box!
    Z12 proMax doesn’t exist. Not from Formuler!
    There is only one Z12 Ultra. With Android aosp. And not bigdroid.
    Z12 comes with 128gb storage and not25.gb.
    Google Search
    This is not a formuler box.
    Maby they cracked the z11 and make it z12 with other firmware/android software 😂🤷🏻‍♂️
    I'm going crazy trying to find the download link, where is it, i tried everything i could think of.
    i need an update for this a Z12 ProMax which comes with a BigdroidOS 2.0.1 and netflix is not working on it, can you please help and give me the link to the update file?
    Updates are over the air. No lossless files.
    And z12 comes with android 12, not bigdroid 2.0.1
    H264 and h264 plays since mytvonline, mytvonline2 and mytvonline3 just fine.
    Turn off vpn and test.
    And check at surfshark for chameleon protocol.
    With nordvpn it's called an Obfuscated server.
    In spain as example they slow down internet speed while using vpn for iptv streaming.
    When i adviced a friend to take Nordvpn and choose Obfuscated server problem was solved.
    Obfuscated servers are for the internet provider to see as normal https traffic.
    In short: they don't see you use a vpn then.
    Surfshark has also that option, maby with an expensiver subscription. It's called chameleon server i thought.
    Try if you have a good subscription with the chameleon server and connect to that one and try.
    The issue that I have seen on my buddies system is a codec issue..
    I know there are other players out there... But if I buy a Brand new car and the manufacturer sys there is a brake broblem but gong to a different garage to get it fixed is not the answer I would expect... It should work.. new out of the box
    Strange all standard codecs are implemented look to me.
    H263, h264 h265 vp9 av1 etc
    Must be a special or old codec, that it won't play.
    I never had a vod movie on my 5 provider what couldn't play cause no codec.
    My friend hopes so too...
    I wonder if they actually bother to do any real testing on these boxes or are they just interested in getting a new and mega expensive box out on the market?
    Why dont they have a "Codec" app in " Market " It would be a simple fix rather than a complete "hotfix" that could delete all infor.. similar to the MOL2 update they released for newer z10 boxes..
    Having said that... a 22€ app fixes the OTT player problems!
    Codec app?
    Why that? Kodi, vlc, novaplayer, mx player etc. So many videoplayers.
    Or do you mean iptv player?
    22 euro?
    I got myself 5 providers, never ever had that.
    One time only black screen for 5 seconds with a vod, then rewind and movie played like a charm.
    That was on my Z12 only.
    Not on my Z11. So Z11 is unaffected.
    Should be something with Android 12.
    But a big fix is on it's way...
    ...but when? No one knows. I still hope it become in march.
    Ok, but then why did it always work? Did Netflix change something in this new version?
    Are you saying that none of the formuler boxes you will not be able to have Netflix app working?
    Regards
    Yes, netflix didn't licenced Formuler boxes unfortunately.
    Some say the only version from the market store works. But only with mouse en keyboard.
    Some chinese boxes supports netflix, but they cracked the netflix certification and Formuler is a good company who doesn't do such things like illegal crackings the netflix app.
    Every smart tv the last 15+ years has netflix.
    Wish you a goodday my friend.
    I factory reset and downloaded the latest version of Mytvonline+
    In content sources it asks for provider Portal URL
    My provider is **** and they refused to give it as it was not an approved ***** device
    I have used the app for the last year with no problems
    Any advice?
    Are you using a box? Which one?
    So we can tell you how to reset the box and you are frew to go to which provider you want.
    Please consider to buy the Z11ProMax bt1 edition or the Z12 ultra my friend.
    Hi,it all depends on the frequency and the number of episodes that are released by your IPTV provider, so e.g i have a new tv-serie released by March 14th and 3 episodes are released at once.
    Maybe you can test /search for tv serie"the Madison",and see whether you get same result.
    Youalso can test your Favorites by going into "all episodes".and see if new episodes are added:smiling_face:
    Very well explained!😃😃
    It's not i'm Henkie, but A.I Henkie💪🏻😂
    Today I saw something that I haven't seen before. On TV series that I follow in favorites, the following came up today.
    A series called "Marshalls" where I have seen 2 episodes, today episode 3 came. Then I see on the picture NEW and when I go to the episode a red dot. Attached 2 pictures, so I assume that means a new episode has arrived. But shouldn't I get the same on other series that I follow. I check every day for new episodes. Attached 2 pictures.
    svejoh
    When one episode is new added. Then you see that icon i think also.
    Wil have a look at my side.
    Never saw it again but will test it too.
    Thanks for the post.
    I will take note! Thanks.. if it works, will give feed back if that doesnt work... ( I'll be back!!)
    Contentmanager.... Data Sync... auto update settings
    Thanks again!
    Mytvonline3, menu, Contentmanager, data sync, auto update settings, switch on, time of day 16:00 hours.
    And epg:
    Mytvonline3, menu, Contentmanager, contentsources, choose your portal, edit, epg update interval, 3 hours, THEN CLICK ON update!!
    I have seen with the Z12.. that the EPG simply stops working after a month or so.... Sometimes next day after a new install...
    The only way it was fixed was to delete the MOL3 app.. re install and then re program.
    Refresh.. had no effect.. MOL2 doesnt have the issue..
    Is this a known Bug and will it be fixed or has no one else ever experienced this.?
    Go to mytvonline3, settings, Contentmanager, contentsources, select your iptv subscription, set epg interval to 3 hours, click save!
    Also in Contentmanager you can find somewhere: auto update. Set this to 16:00 hours or so.
    Mytvonline3 should update channels/vod/series everyday between 16:00 hours and 17:00
    So if you are coming home from work or so the box did the refresh already for you. (Sometimes you need to click in menu refresh content, and sometimes it is already happens)
    (And maby it's a know bug, but if i set it to 16:00 hours the refresh, it start not exactly on 16:00 hours. Mostly between 16 and 17:00 hours is will do the refesh)
    Goodday my friend
    Since the beginning?
    Send it back in your warrenty period the! Why wait?
    Not after warrenty complaining.
    You bought the cheapest box. Mistake nr 1.
    You didn't sent the device back in your warrenty period, but has then already the problem with it. Mistake nr 2.
    After warrenty you ask formuler to switch it for the Formuler Mini🙈 mistake nr 3.
    Buy a Z11ProMax bt1 edition and or z12 ultra then you have A goodbox my friend.
    The mini needs extra products like usb hub to ethernet etc.
    Please be once smart and buy directly the Formuler Z11 Pro Max bt Edition. (With bluetooth remote)
    Or the Z12 ultra.
    Goodday my friend, i hope you have warrenty yet.
    fichier svp update.img
    There are no update files for boxes to download.
    Only over te air.
    Tey factory reset your box.
    Don't know exactly but there is a Tutorial. Something with push volume up buttton till led blinks or sonon box and then press red button.
    Bit not for sure. Please search google or forum for the factory reset steps.
    I thought you got z8 or so right?
    Anyway. For all boxes are tutorials. Google, forum and youtube.
    Goodluck my friend
    It worked perfectly. Thanks a lot.
    Is it possible to get the latest Netflix app as well? Appreciate the help.
    Regards,
    Bruno
    Hello my friend,
    It was for me a pleasure to do it for you😃
    Netflix don't gave certification to almost all boxes. Some have a netflix certification like nokia, xanomi, nvidia etc.
    But less then 10 boxes from the 1000 that exist.
    Soery bit netflix won't work on Formuler devices, due Netflix itself!
    Stupid are they, as they certified Formuler boxes, netflix got more costumers.
    Use so long netflix on tv if you have. Much better that on the most boxes.
    Goodday my friend
    Make sure your VPN (if you use one) is switched off before switching on the box for the first time or you could Geolock to the wrong purchase region which essentially bricks it and it needs to go back to Formuler to unlock it.
    This info really needs to be on a label on the box or written into the quick setup guide that it comes with.
    Vpn can be on, but you need to know if you buy an European box your vpn is connected with an European country. And not with usa or so.
    But the most people have no vpn on router, but on box itself.
    Anyway, you can activate box if you have vpn on your router.
    Just check first if you have an European box or USA box by asking seller.
    Or simple turn off vpn on router first and or make wifi hotspot with mobile phone before connect to your router.
    And hope that the ebay/amazon sellere sent you the right box.
    Sometimes american sellers will make a mistake to sell there box to european customers. And then it goed wrong.
    I advice always to buy at store in your country.
    Hi All, I am struggling to find this issue when I search, so please feel free to point me to the right thread if possible!
    Every time I change the URL for one of my portal sources, MyTVOnline3 essentially makes me go through the Live/VOD/Series setup all over again. Is there a way to edit the content source without having to start over?
    Thanks!
    No, so it is now...
    ...if you change dns/url.
    Portal connects to new dns and it ask the same questions yes if you want some groups or not.
    Nothing to do about it.
    Maby a tip for future update of mytvonline3?
    I don't know, but it's now for years now.
    And since end 2025, a lot of dns were blocked till this day.
    So don't do to much...
    ...dns's will be blocked by netherlands, Italy, france, spain etc...
    Goodday my friend
    Thanks again. I’ve understood the lesson.
    The second Z12 device I bought is working properly and I like it a lot.
    Now, the point of this post is to figure out how to get a response from the seller, who is making me wait unnecessarily by claiming that I “damaged” the device, even though they have the option to refund me or send me a similar device.
    Youb didn't damaged the device.
    They must send you a new one. And they must send the geo-blocked box to formuler back.
    That's not you business. You have the right to get new one.
    What is the difference with HDMI then? Why could that cause a problem?
    The hdmi cable supports QMS.
    so if your tv supports it, and you change channel from a Dutch channel (50fps) to an USA channel which is 23fps, you shouldn't see a 2 seconds black screen if AFR is enabled.
    If you have AFR enabled and your tv doesn't support QMS you see 2 seconds black screen or so.
    If your tv supports QMS (Quick Media Switching)
    And you use original cable, you won't see anymore the 2 seconds black screen if you change a tv channel from 50fps to 23fps, or from 23fps to 50fps.
