Disconect box, after conect e onli led red e dont work, no image.
Tanks
Tanks
Disconnect again from power and connect, if still red and doesn`t change or boot then is possible that your power adapter fail. Try then with other power adapter with same specs.
Iám Try 3 diferents chargers, dont result.
Looks like it's broken. You can try other hdmi port and then have a look what the box does.
dont work hdmi 2 diferent led tv.
Ok, if other power adapter doesn`t help and after each connect the box shows only red led + doesn`t switch then is the box faulty. If warranty still exist, contact your seller.
Is possivel put software download to try force in pen drive?
Fact is you can do nothing, even factory reset is not possible when the led shows all the time red light, the bootloader doesn`t start.
Not possivel anoter software? control remote red buton not change nathing
No, search Tutorial please. If not work.
Bootloader broken and or faulty power adapter?
<problem is not power adaptor, box disconected an 3 days later dont work more. iám try more 2 power suply formuler original inclued.
This is the box we speak about, right?-> Formuler Z+ neo description and specifications
I will explain again. If the Box, after it was powerless and power adapter cable insert, shows only red led light but doesn`t change to white -> is the power adapter faulty or box damaged. You say that you tested other power supply and same also with new PS, then is your box damaged. You can not in this case proceed with factory reset or some software update if the box doesn`t work and hardware faulty.
Chinese material, Ok tanks, go put in the trash chinese material.
Korean✅️
