RTP it's the broadcaster name not the stream format. The stream is AAC/H264 as others that play. I attached a small sample of channels. Those from RTP broadcaster don't play on MYTV.
That plays aac, h264, h265 etc.
Let me check here
Let me check here
Hi. There is a portuguese m3u list that contains the free over-the-air channels. However the channels from the portuguese national broadcaster don't play on MYTV 2 on my Z10 neo or on MYTVonline app (both iOS and Android). This is one of those channels. I watch it with no problem on GSE IPTV app or even on the browser:
https://streaming-live.rtp.pt/liverepeater/s…l/playlist.m3u8
Is there a solution for this?
Will test it later on my Z11.
Try first in mytvonline to remove the "s" from the link.
So not https://....
but try http://...
Can you give channels what won't work? So i can check
Will have a look after breakfast.
I did clear cache etc. I'll try doing the back up and re-install, thanks.
Please let me/us know if it solved your problem my friend.
Can the developers remove the premium activation until the time comes that users need it. Whatever the last update did means you have to reactivate Premium every 24 hours. If its free. Why do we bother? I'd honestly pay an activation fee at this point. That said, new users will not pay that fee if you are trying to entice them to buy boxes.
If you delete the app from phone.
And reinstall it.
I tested it myself on android phone.
I need to activate again.
So if you uninstall it and reinstall it, dont click on premium services then.
Basically i have no app in the launcher set to auto start.
If I open the MOL3 app from the app drawer it loads the last live channel which is fine
If I scroll down to "history" of TV shows, click an episode and click play, it starts playing in MOL3 but then after 5 seconds or so it launches the last live tv channel played. I then have to go back into TV series and click play again.
I understand your problem now my friend.
When you resume a serie mol3 returns automatically to live tv.
You deleted cache already from mytvonline3 and reboot box?
If not? Try it please.
Tested it on my end, and here all fine.
Try with an usb making backup of mytvonline3 from mytvonline3 menu.
Remove mytvonline3.
Restart box (not standby, but reboot)
Install mytvonline3 from market app and or software update.
Import your backup from usb via mytvonline3 menu.
Test again please.
When u use formuler box.
Be sure that tivimate on your firestick is off!
For test you can do.
Get Firestick out of tv.
Then start formuler box.
Start mytvonline3
And test again.
If you have now image. It means your Firestick with your subscription is in use on background and you have one subscription.
one connection at the time. (Mostly)
Recently bought a z12 ultra, loving the box, I like the home screen shortcuts to VOD and MOL3 seems a sold app all round.
The only issue I have is I have set my homescreen to show the viewing history for TV series & Movies, but if I launch a TV series from here it starts playing in MOL3 then a few seconds later it jumps straight to live, so then I have to exit live and re-launch the series again, quite annoying. My TV is set to start over in the player settings and in the launcher there is no app set to launch at start up. Just wondered if anyone knew why it does this and how to stop it?
Cheers.
I don't know what you actually mean in your message. But on desktop if you go to cogwheel right corner there you find launcher settings. There can you setup mytvonline as startup app.
And in history and favorites settings you can switch the live, vod and series on for the desktop.
I didn't. It's for me to much on the screen.
But that it goes to live when you watch a serie i can't figure out.
Did you try it with other serie to test?
This bug is about the replay functionality, i hope you all understand.
Lets say that i have 7 days EPG, 7 days in the past and 7 days in the future.But i only have 4 DAYS REPLAY.
If i go to EPG on MOL3 and MOL+ , 5, 6, 7 days ago, the replay icon shows on all programs that had replay before, even if the replay isn't available anymore, and off course if someone try to open it, it will give error....
This was something that happen on MOL2 at the beginning but then it was fixed...
Try refresh your content first.
Maby its too old and or provider related problem.
This is happening since the beginning of mol3 on all Z11.
A lot of times the player starts the movie but it does not play any picture or sound and the resume bar is completely full / white, like, the movie is already Finnish, but it should be starting... ive made a reports, opened support tickets and nothing.MOVIE STARTS, PLAY BAR IS FULL WHITE AND NO PICTURE OR SOUND. TIME CONTINUES LIKE IF THE MOVIE IS PLAYING....
IF WE TOUCH THE LEFT ARROW TO GO BACK TO THE BEGINNING IT STARTS NORMALY....
VIDEO H264, AUDIO MULTIPLE LANGUAGES AAC 5.1 AND 2.0
Try from the app formuler market (green logo with white trolly) app to download audio optimizer app.
Install it and load it please. Box reboots.
And then try again?
Or try vlc player or kodi.
You can setup it as default player in mytvonline3 menu.
Display MoreHi,
Since a week, or so, all the movie group in MYTV+ or MYTV3 ask for the pin code, just like the adult group.
In other apps, it doesn't, with the same "service".
Any thoughts?
Cheers
0000 is normal code.
check mytvonline3, menu and then parental options.
If you have no kids...
...deselect Lock adult categories and deselect menu lock if it's on.
If not's that, contact provider that you have code in all groups. Maby they made a mistake and select all groups use with code.
Thank you. SmartTube wont load for me either on my Z11 PRO. SmartTube app version is 27.03.
I get an error playing a video: instance().evaluate(clientPlaybackNonceCode) must be null
I dont understand the error.
Latest version is 30.19 or so.
And whe installed go to information and switch update dialog on! So you see everytime that an update is available.
Check your pm please, also petercs272 at https://www.formuler-support.tv/conversation-list/
If it’s not work, then has youtube something changed or so in Usa/canada.
Works fine here.
Youtube wont start on my new z11 pro either.
I have two z11 pros. Bought one a year ago that youtube works.
New one bought last week. That will not open youtube.
Did you download it from google playstore or the market app (green logo)
Downloaded yet youtube from google play store on my Z11.
It’s version 5.30.304 from july 7 2025.
i get screen to log in, or create account or watch as guest.
I choose watch as guest.
Search for gordon ramsay.
And it works here.
2 commercials and then the gordon ramsay video
That
It was XC api. I just reinstalled Mytvonline3 so we'll see if that helps
I hope it works out for you.
I think it does💪🏻
If you next time get box from europe.
Install (free) vpn on your phone.
Make connection with europe country on your phone.
Make from your phone a wifi hotspot!
Start your formuler box (without utp cable)
Connect with box to your wifi on your phone which has a vpn connection to european country.
Update box and restart.
Should fix the geoblock.
After restart and its working fine then you should put in the utp cable. And should be no problem anymore.
I am suddenly seeing this identical problem on both my Z10 and GTV. I note that this thread is a year old, but for me all channels have loaded correctly until a week ago. Now mol2 loads 31000 or so channels, and then number 35056 and nothing else. Is there any likelihood that this bug gets fixed?
Contact your provider and let them delete all the countries you don't watch.
Give them Only the countries you watch, let them put them in your Subscription.
Less loading and faster portal connection.
Goodday my friend
Workaround on phone with a vpn connected to european country is a great idea. Nice one of you!💪🏻
If your box makes connection with the wifi on phone it has direct vpn connection and youn can set it up.
After that "i read" on forum on should be working over the world.
But i don't think this work anymore, cause when you startup your Z12 the block is already there, and the box shutdown itselfs.
You can always try, but i heard users said it shutdown directly.
Sent it back for another one.
Then it should work if you use your phone as vpn with europe connected and make with box wifi connection to phone. Should work i think.
Don't make the mistake to put also a utp cable in it the first time😉
When I restart my z11 pro max it takes 3-4 minutes for mytvonline to start. Then I noticed that my channels stop working lately. I have to take out the power cable and plug it back in for the channels to work.
What could be the cause?
Do you use it every day the box or sometimes in the week.
I started last in other room z11 on and i waited 3 minutes for that mytvonline3 was started. Cause it's was a week offline, it gets new content by the start of mytvonline3.
I checked it for sure and the refresh date was november 1. So that was at my side the reason.
Will try it tomorrow, cause i deleted youtube with adb tv.
I use smarttube and newpipe.
I install it tomorrow on z11
My assumption is connecting to the VPN causes a network change in the Android OS that causes the Network Storage to disconnect. Since there is no auto-reconnect (only on startup) it remains disconnected until you manually mount the Network Share again.
Thanks for looking into it, hopefully there is a resolution.
That's it. Smart one!
They should extend the time to reconnect to 30 seconds or so.
Can you expand on this please - - HOW did you do this exactly?
Hold ok button in on youtube app.
Then information
Then delete updates
Has anyone been able to get Dolby truehd to work using the internal player for mytvonline3? It works using Kodi as an external player for VOD however plays as stereo pcm using internal player
Did you try to go to mytvonline3, menu, settings, player options, external vod player and set kodi as standard vod player?
Maby is the internal just a fine standard player. What can play some audio but not all.
I had a Z8 for many years and attached a external HDD for recordings. Now I bought the new Z12 ultra and wanted to attach that same HDD to it. But it doesn't connect. Under device preferences - storage - removable storage I see the HDD but it says safely ejected.
Maby you need an external usb hub with extra power?
that's because you have a hdd that maby needs more power?
Something like this?
Power adapter is powersocket in wall.
The usb cable in Z12. And usb from your hdd in that usb hub.
I use it with my raspberry pi 5, when i had problems with power and files lost due lack of power.
can anyone please tell me where i can purchase the gtv-bt3 remote by itself? i have struck out trying to find out where
It’s not in stores yet so far i know.
Only delivered with the Z12.
But it will comes in stores separate.
Okay thanks, I was hoping that is was visible without turning on/off
If the led is red it's off.
White is on.
But you hide your box, so than is this so far the solution i think.
Goodday my friend
I like the BT remote control for the Z12 ultra, advantage I could build in my Z12 and can control it without any issues.
Disadvantage that I cannot see if the Z12 is on or off, it would be great if the IR Remote Formuler TV app (android) would support the BT3 remote control and show the status of the Z12 Ultra.
Or is there maybe another option to see the status of the Z12 ?
Just switch to your hdmi port with use of the source button on your remote.
If you got image, your z12 is on. No image and press on button then.
Other option is almost onpossible to integrate on remote.
Bonjour ,
Merci pour vos réponses.
J ai tester mais rien ne fait ,
je pense que je doit me dire qu il est HS 😣
English only please.
If hard reset didn't work and also not on other tv or pc screen.
Try another power adapter with same specs.
Or device is broken....
My Formuler device won’t start anymore, and I can’t perform a reset because there’s no image and the manual reset doesn’t work either.
It stays on with a red LED light and doesn’t respond to the remote control. I’ve unplugged it from the power outlet and plugged it back in, but nothing changes — it remains red.
I’ve also replaced the HDMI cable.
What should I do?
Thank you.
Test it on other tv and or pc monitor.
And different power socket. Can be many things.
Try reset your box. Find hard reset movie on google.
But if you put power in on backsite of box it should automatic start up.
Is it the original adapter? If no, use original adapter.
Try other adapter with same specs!
If (new) adapter and factory reset not work, and still no image so you can't give it a factory reset... It’s dead then i think.
Try formuler remote app!
Open it, choose your remote.
Setup ir volume
Then you see screen with android volume on the left.
Change that volumebar on to the middle. (I think it completely at the right, so put the ball to the middle)
Then click continue.
It's something like those steps. I'm not at my device, so It's maby not exactly whom i said. But have a look in the formuler remote app an change ANDROID volume bar to the middle. Or lower. Test it please
Goodday my friend
I live in Australia and received the Z12 Iltra purchased from Amazon. I get this message
This product is not for sale outside EU/UK region. Contact your seller
I'm going to return back to Amazon. I have not been able to find a solution on line. Where can I purchase this device so it will be compatible in my country?
Sent it back!
Buy here: https://crosslinkstrade.com.au/collections/formuler
Edit: i see they have not yet the z12 in stock on there website.
Edit 2: i emailed them when the z12 is in stock.
SAM F_Peter do one of you two knows an another Australian Formuler seller who has a z12 ultra?
Open Formuler Remote app > Go to "Setup IR Control" and select your TV brand.
After everything is programmed, press and hold the TV/STB button at the top of the remote until the light blinks red 3 times.Now the majority of the buttons on the remote will control your TV (including the OK button).
Press and hold the TV/STB button until it blinks 3 times again to toggle back to controlling your Formuler.
I knew that. But not that you could also use the ok button on the remote. Again learnt something.
Thanks.
in short summary: box is started up, then connected to nas. Then makes the vpn connection and when vpn is connected it disconnecting the NAS. Also with ALL APPS splittunneling! (including all systemapps and mytvonline3.)
When i check with ip app from google playstore, i have the exact same ip address what nordvpn gives me.
Note: I use a raspberry pi 5 with openmediavault
Around 22k
Advice: contact your iptv provider. And let the remove all the countries from your subs WHAT YOU DON'T WATCH.
example: if you life in france or so, i dont think you watch russia, poland, africa etc. That countries can you remove then by provider. Only the countries you want to watch, that's what you need.
Less time to load portal also and faster working mytvonline and box etc.
Lucky is the best. I dont know where he gets the motivation from but he really tries to help everybody here and ofc thats not easy and sometimes you get fed up with people. I respect him for what he does on this forum. Kudos to Lucky!
Many thanks for your kind words my friend Mevi
Your advice is the opposite of what he’s asking for though. He’s asking on behalf of his provider to have a hidden url, whereas you’re telling him how to remove a provider lock.
Although I agree on changing provider
Url is standard hidden. Only see if you click on the eye.
Otherwise he should ask for the mol.cfg editor. And do it self if possible. Don't know if formuler give it to standard users.
