Ready to buy another CC box because it has the ota connection. Does the Z12 Ultra have that feature? If not is another box recommended over the CC?
Can it be that there are also usb ota dongles?
Search forum
Search forum
Sorry, its already done i see. Maby you can the "private dns set to OFF!"
Is on your internet provider router maby also cloudfare as dns?
If so, login on router and change to quad9.
And contact your iptv seller that you have this problem now.
Maby there streams are leaded via cloudfare.
Try a free vpn. Install it and connect to to your homecountry. If it works then it should be buffering maby due a free vpn. But you know then problem is solved.
Then think about to take a paid vpn like nordvpn. Very good costumer service also.
Been playing with this box for a few hours set up MOL3 and installed additional apps Disney+, Prime Video, Apple TV, Plex etc etc and box itself seems fine I have a 77” LG C4 Tv with a Sonos arc ultra soundbar with the rear speakers and the sub etc connected via hdmi arc loaded up Apple TV the gorge film and boom Dolby vision and Dolby atmos came up on screen so was happy there but load prime video and Disney+ etc what has Dolby atmos content and wether I’m missing something or not a cannot get anything Dolby atmos from those apps, loaded a plex 4k movie and boom that loaded Dolby vision and Dolby atmos fine but seems a can’t get Disney+ or prime to give out atmos audio anyone else reflect any light on this or ewt
Cheers
Thanks for sharing your results.
I thought dolby atmos and dolby vision was working on disney plus and or skyshowtime, prime etc.
But it doesn't you tested?
Thats bad news. Then keep i watching it via my lg tv app.
P.s: i think it should work if there was official AndroidTV software on it. Correct me if i am wrong.
Goodday my friend.
Quick test before bed. Er ye. Plex streaming doesnt seem to be great
havent seen atmos logo pop up once. dolby vision rarely. lots of vids not playing. pfft.
Can also be plex my friend. Maby it needs an update.
I dont use plex. Dont like it.
I play .mkv files via Raspberry Pi 5 with ssd connected by usb via my network.
I plays great with vlc player, mx player and nova player
I’ll give that a go as it’s currently set as 24 hours
Don't forget after the change to push on the bottom butten "update". (Save setting)
Exactly the same set as before xc
Also set in Contentmanager at your subscription the epg interval at 3 hours?
Maybe an update to the remote software will be able to swap the volume buttons around?
Display MoreCan you please test using MOL3?
For Dolby vision and true hd .
Thanks to all
Just for information using the Z11 pm the true hd audio signals are already working only using Kodi as external player but not using MOL3.
So according to the recent feedbacks I ve the feeling that for audio it is the same than the Z11 only Dolby vision support is the new feature for me .
For the tester: i know sky uk or usa main has with an event dolby atmos sound.
Saw it one time with my z11.
Dolby vision can you only test in the vod section i think.
no channel so far i know broadcast with dolby vision. (Note: your tv must have dolby vision support, for the people who dont know it.
No, it doesn’t work like with the Z8/10/11. The BT1 had two main volume buttons on the remote itself. The BT3 has adjustable volume buttons on the side, which is extremely inconvenient! The volume buttons on the remote itself only work via IR in TV mode.
It is a bluetooth remote.
Maby they bring an update out fot the bt3 and formuler remote app. So that we can change it like before.
I dont have a z12 (yet).
I tested my Z12 Ultra today.
I’m one of the 100% who wants to use the main volume buttons to control the volume of my tv/soundbar/surround set/everything. I don’t care about the box volume.
The fix:
I don’t use the new Z12 remote. I linked my good old one Z11 BT1 remote 🙈
Isnt it possible to open the app formuler remote? Inst that installed on the box?
And setup your remote to your tv brand?
Must be possible looks like to me my friend. Like Z11, gtv, z8
You can create new rows and sort apps from left to right and other way.
I have it too.
First row (tv things): mytvonline3, disney plus, skyshowtime, hbo and stremio.
second row (other): file manager plus (for NAS), spotify etc
Goodluck my friend.
Display MoreHello, I'm also curious to know if Dolby TrueHD (Atmos or not) works well in passthrough, like DTS.
Since they don't mention it, it doesn't look promising...
Because the "Dolby Atmos" certification doesn't mean much, considering there's a Dolby Digital Plus Atmos version that is completely different...
It would be good to know if QMS is supported on this model, like on the Z Mini, which doesn't have the same SoC...
Having HDMI 2.1 isn't enough
This option is very convenient when you have a compatible TV (only Samsung and LG since 2023).
Edit : I just ordered one on Amazon France.
Just to test it out, I’ll send it back afterward because it’s a box that’s way too expensive for what it is (unless, of course, it supports all audio formats in passthrough on all app, that Dolby Vision works on all applications, and that QMS is functional).
It’s a shame it doesn’t support Netflix, though, since it’s not true Android TV
But in theory, Amazon Prime is fine; we’ll see if Dolby Vision is indeed available there.
1 thing: don't blame Formuler that Netflix don't work on there devices.
Thats cause Netflix doesn't certified these boxes.
Lucky for you that since many years now all tv's have Netflix installed.
Will download it today and test it.
Oh and richi207: many thanks for making an app. Nice work my man.
Its a dark day know sow something to do inside the house now so i gonna test it
Yes,i have the box on standby and refresh every day at 00.50 AM,no problem.
I also standby.
Refresh at 16 pm.
Within 1 hours its refreshed and updated with new content
Wifi 5 is less sensitive then 2.4 ghz.
2.4ghz has a longer range
5ghz a shorter range.
If you are (to far) from router use 2.4 ghz
Mol4 won't come to any older boxes.
Mol4 should come in future with a new box.
i wont come to z12, z11 etc..
I did purchase an EPG server. You cannot add it to XC, only m3u in MTOL3. It works fine on my phone, on my home network, through the same VPN, in MTOL3+. Why does it fail on my Z11 with MTOL3???
I know it can only with m3u ofcourse.
Didn't know you already had a paid epg server.
It works on your phone, but not on your z11.
Is it a http link or https link?
If its https, try http link on z11.
I will add that I'm running 3 other services simultaneously, all using XC API. This particular service runs fine using XC API, but will not connect using m3u.
Then use xc.
Nothing wrong with that right?
Why m3u if you can do it simple? If you cant get it working with other epg.
Try a paid epg server. Someone on forum had it about it last week.
He had found 2 epg servers.
I will wait user feedbacks about Dolby vision and Atmos true HD 7.1if it is really working like it should be.
Can you confirm it if it has dolby atmos trueHD also? Or only Dolby Atmos.
Then has dedelere his answer.
Not active simultaneously. I do use 1.1.1.1 in my router for DNS, however, I run VPN for my streaming devices through my router as well, so they should see the DNS of the VPN.
Test quad9 dns what sam says.
Its 9.9.9.9 as dns.
Display MoreHello everyone,
I’m hoping someone can help me with an issue I’m experiencing between MYTVOnline3 (Formuler box) and MYTVOnline+ (iPad app).
- I have a Stalker portal with Mac registration that works perfectly on MYTVOnline3 — Live TV, VOD, and Series all load and play fine.
- When I use the same portal on MYTVOnline+ (iPad), it recognizes Live TV and VOD, but the Series section shows “0” items.
So far, I’ve tried reinstalling the app and re-adding the portal, but the issue persists.
Has anyone else run into this? Is this a limitation of the iOS app when using portal URL with disabled login, or is there a setting/workaround to get Series to show up like they do on MYTVOnline3?
Any guidance would be appreciated!
Thanks in advance.
Did you shutdown your box fully? So no standby.
If you have one connection. Then refresh sub on tablet.
Settings, content...., hold on your sub and push refresh?
Maby it helps?
Ant idea when and where to purchase new remote?
Around september 10/11 i think
Is the BT3 also available as a stand alone item for sale,without the z12Ultra,and does it work on the z11promax?
Yes.
Did we still need audio optimizer in the T12 or are the codecs finally embedded?
Good question! And the answer is even better.
Less audio problems if someone have costumers👌🏻
No need to explain anymore if they skipped the audiocodec download and then say that they need to download audio optimizer.
Good job formuler
Hi, Do you have a list of official resellers for France? Thank you
No discussions about iptv sellers.
Only sellers for formuler devices?
Do you mean that? Formuler devices?
On my lg tv from 2023 its in hdmi port 4.
And no problems.
Deep colour on
And z11 settings for image on auto
Hello
I dn't understand why some vidéos does'nt work in the same serie ?
Regards
Provider related. I think almost every provider has a serie or movie what didn’t work. With 10k or 100k+ series and movies.
You can always try to refresh your sub via mytvonline menu and then try again.
If not help contact your iptv provider
It's an IR remote. But good idea to try reset of the remote.
I dont know if you can reset a ir remote.
But give it a try and let me know.
Thanks I've changed epg to 3 hours
Good job my friend.
Am having a similar issue. My Z11 box just turns off when I hit the down button. It's almost like some buttons are mapped to shut down the box, if you hold them or double press them, similar to scrolling.
Sorry. With mine it's tuning my HDTV off. We do have hdmi-cec turned on.
Bt1 remote?
Remove bt1 remote at bluetooth in android settings
Already reset remote my friend?
hold 0 + menu button for few seconds.
Give it a try and then reconnect it with bluetooth on box
So just had success with create a fake M3U file and using a third party EPG to give me 48 hours of data for most channels. Am using either the EPG.BEST company for $13 a year, or the MYEPG.TOP for $7 a year.
Just add in your normal source. Then add an additional source with fake M3U and real XML. The MOL3 app will automatically match up all available channels with 48 hours of EPG data.
I already know that trick with m3u.
But many thanks for sharing it with us. For people who doesn't knew it or want to do it.
Thanks again
Display MoreSorry, don't know how to set epg mode to alternative.
Epg interval where do I view this?
Can't see option to set epg to update every 3 hours?
I can only select time of day to schedule update see attached screen shot. Goes in 1 hour intervals and you can only select one time.
Mytvonline3, menu, Contentmanager, content, choose your provider and then edit.
There you find epg interval (set it to 3 hours)
And if you are on mac connection tou see also epg to change alternate.
So, is it certain that this chipset supports Dolby Vision? I am a bit confused...
SAM said its a revision of that chip. So board is better now. Supported with dolby atmos and Dolby Vision, wifi 6 and bluetooth 5.2
Try first other app like Peter said.
Then you can try.
Delete cache from mytvonline.
Restart box.
If not helped, delete mytvonline.
Restart box.
Install mytvonline from market app and try again.
Last option: factory reset.
