Posts by Lucky13
    Z11 behaves the same, quite annoying. Imho it should disconnect from headphones/speakers once it enters standby, pls change this.
    Standby function is simply said "screen off" function and less power use. So the apps are still running.
    The reason they don't disconnect bluetoot, is that the bluetooth remote also disconnect then if you have the bt1 remote.
    So to fix this "problem": set your box from standby to shutdown/power off function in android settings.
    Problem solved.
    (And the +-20 seconds booting is nothing wrong with Right? You have time to watch tv, so the 20 seconds for booting is nothing)
    Set z12 from standby to power off?
    Only way i think.
    Absolutely not, i'm a software engineer since nearly 30 years and if done correctly a crash must not occur
    Software contains also bugs my friend.
    Look at microsoft, every Thursday it's patch day for windows 10, 11 and server.
    Anyway, wish you a good day and nice weekend😃
    Hello everyone, I tried searching this and couldn't find an answer. I'm going on vacation next week to Florida, I live in Toronto Canada. Just want to know if I can bring my Formuler Z10 SE with me and use it there without any problems. Thanks in advance.
    Should be no problem.
    But let your provider know that you travel to florida usa. So they can set the "watch" country to usa or better to vpn.
    Then you can watch everywhere. But maby it's already done. Who knows.
    But for sure contact provider already.
    I have already tried everything; it works with the outdated Telenet app, but not with the Play Sports app then I get the same error message, and this is what I need. Why doesn't it work on the Formuler when I want to download it from the Google Play Store?
    I have 10 Formuler Z10 Pro here and they are all giving me this problem. A few months ago everything was still ok.
    I tested it with a Z Mini and it works there, but on a Formuler Z11 it doesn't work, and on the other Formuler Z11 it does?
    Can this be resolved?
    Try this one.
    Play Sports_v5.26.14007.apk
    1 file sent via WeTransfer, the simplest way to send your files around the world
    we.tl
    Hope it works out for you
    Thanks Lucky - I'm away from home for a few days - I'll try a few things when I get home. Yes - understood on the two sets of volume buttons. It would be great if Formuler offered a setting for this to switch the function of the two buttons over: my perfect setup would be volume buttons for the TV on the front face, and volume buttons for the box on the right side. But I will learn to use them the other way around.
    I read that a lot of user want that, that formuler change the volume buttons for the tv from the right side to the front face volume buttons.
    Maby it's possible with a future update, i think it would be great too.
    Hi - it is an LG TV.
    When checking the correct IR control, the TV volume was moved up and down as part of the test process. But then after, the dedicated keys on the side of the remote did not have any effect.
    Keep trying.
    Otherwise unpair remote and pair again and setup remote with formuler remote app.
    Bt3 remote has the volume buttons on the RIGHT side of the remote. (In case you didn't know that )
    Hi Lucky, appreciate the response and yes of course, I know it is a Beta, but this was an infinite loop situation. The Clown Fish screen I referenced is the second option to your right after it asks to select a startup screen. Right now, I have it all working again :smiling_face: When I reset to Factory, I thought I would be able to still use MOL3 but I guess because of the firmware update, it only allowed me to reinstall MOL4
    So far i know is mol4 beta offline. (Correct me if im wrong)
    So if you make an backup and do factory reset, then you are able to install mol3 so far i know.
    Beta mol4 was temporary online.
    I also have developer options turned on, is there some thing i can run to get a log or run some tests for you guys to narrow it down?
    If it happens you can after it happens send logs and note log number here what you see on screen before send it.
    How to send logs:
    If problem comes, cogwheel on homescreen, helpcentre, report a problem, NOTE OR MAKE PHOTO OF TRACKING NUMBER ON THE LEFT PAGE, send logs then and write down log number here.
    Hope this helps, and if you found it, reboot box and check again.
    How to Verify and Adjust Settings
    While Deep Colour is usually automatic, you can manage it via the TV's menu: [1]
    1. Press the Menu button on your Panasonic remote.
    2. Navigate to Setup > Display or Picture Settings.
    3. Look for HDMI HDR Setting or HDMI Settings.
    4. Ensure the setting is toggled On specifically for the HDMI port your device (e.g., PlayStation, Xbox, 4K Blu-ray player) is connected
    The exact type is 4K Panasonic TX 50CX670E - 50" - VIERA CX670 Series LED-tv.
    I don't think it's anything TV related, it worked before and i have not changed any settings to my tv, the formuler had a crash and suddenly it's back to the issues from before, but everything else is still the same.
    these are my tv settings but i don't see anything that would cause this and disabled most of it.
    also can't force the tv in 4k, it adjusts to the device output.
    Hdmi deep colour can you maby find in hdmi settings. Or somewhere else.
    Screen settings, screen option?
    MOL4 CRASHING / STUCK IN A LOOP
    Everything has been working just fine since I loaded the BETA when it came out. Last night, mysteriously I turned on my Z12 and when trying to open MOL4 it got stuck in a loop. It would try to open, the screen would flash and then the MOL4 logo screen comes up, tries to open, flash and keep repeating itself. I tried everything to get it to stop. I was able to hit the Home Button and all other apps works fine.
    I had to wipe the unit to factory, reinstalled MOL4 and after I setup my first PORTAL, it asked me to select my startup screen, I selected the first one that appears in the menu and then the screen flashed, MOL4 crashed and it went right back into the loop issue.
    I reset the unit again to factory and after I loaded my first PORTAL, this time I selected the second screen option with the "CLOWN FISH" picture. It worked and I was then able to load my second PORTAL. I was up all night getting this to work properly and I want to know, has this been a problem? When do we think a final version is coming. I would now consider MOL4 BETA to be a mess 😒
    I can't find a clown fish logo. Only whale.
    Anyway you can make backup with usb stick from mol4 after setting up portals.
    Mol4 menu, app settings, backup & restore. Then you don't need to type all your portals.
    Just restore it after a reset with the usb.
    Yes, i have sometimes crashes too. It's close itself while watching live channels and or scrolling in groups.
    But It's a beta.
    I remove data and cache from mol4 and restore backup via usb. Then often it work for some days.
    Hello, yes i did use the hdmi that came with the box, also tried other HDMI cables but they have the same issue.
    All ports have the same issue and are the same on my TV except HDMI 1 is the only with ARC but that should not be the issue, the Formuler is directly connected to the TV (only have 3 HDMI ports).
    What kind of tv do you have? 4k tv or full hd?
    If you have 4k tv check in tv settings at image/screen options. Like hdmi deep colour on etc.
    Audio Optimizer isn't nessesary on Z12 box.
    Do you use original hdmi cable from z12 box?
    Is the cable direct from z12 to tv? Not via a soundbar. Direct to tv.
    Some tv's have hdmi port which are better. Like lg as example.
    Try port 4 hdmi or so. Sometimes it's written at a hdmi port. (4k 120hz) as example.
    The app adb manager ask also that if you installed and use it.
    Turn off developers mode in android settings with the switch.
    Go to cogwheel on apps desktop upper right corner, And click again on cogwheel --> device Preferences, look if you can find
    "{ } Developer options", if yes, click on it, turn off with switch "enable developer options". Then it also disappear in the device Preferences menu.
    Restart box and check again.
    This is not a mytvonline problem.
    Never ever saw it. Check for strange apps or do direct factory reset If developers options are not there in "device Preferences menu".
    Hi - did anyone ever get to the bottom of this? I just purchased a BT3 remote, because I want the better functionality. When I pair it to the Z-mini box, it pairs fine. I can use it to control the z-mini box, alongside the original BT1 remote. However, in the Formuler Remote App it shows as disconnected (even though can see battery level), and therefore I'm unable to configure it to work with my particular TV brand which makes buying the remote seem dumb.
    So - BT3 successfully paired to Z-mini box, but Formuler Remote App is not recognising it. I've unpaired and re-paired it. Any other ideas?
    Unpair and remove first in bluetooth settings the old BT1 remote.
    Also the new BT3 remote.
    Reboot device!
    Then pair new remote via bluetooth again.
    Give it a try my friend.
    Let me know if it worked out for you.
    Which tv brand you have? Some (B) tv brands use the codes of other brand.
    Goodday.
    P.s.: if you connect both remotes, the bt1 and bt3, then the formuler app can't handle it ofcourse. It can only show info from one remote.
