Bluetooth headphones remain connected whilst Z12 Ultra is in Standby Mode
  • I have Sony WH 1000X headphones and I’ve paired them with the Formuler Z12 Ultra. However I have found that when putting the device in standby mode the headphones remain connected to the Z12, meaning I can’t connect them to another device without fully powering off the Z12. If I power off the headphones and turn them back on they will connect to the Z12 even though it is in standby mode.
    Ideally I’d want the headphones to disconnect when putting the Z12 into standby mode and then attempt to reconnect when I wake the Z12.
    Does anybody know how to achieve this?
    FYI: My headphones do have multi-point, so I can use another device whilst paired to the Z12, but I use various Bluetooth devices and don’t want one the Z12 to occupy a connection point when on standby
  • Set z12 from standby to power off?
    Only way i think.
  • Z11 behaves the same, quite annoying. Imho it should disconnect from headphones/speakers once it enters standby, pls change this.
    Standby function is simply said "screen off" function and less power use. So the apps are still running.
    The reason they don't disconnect bluetoot, is that the bluetooth remote also disconnect then if you have the bt1 remote.
    So to fix this "problem": set your box from standby to shutdown/power off function in android settings.
    Problem solved.
    (And the +-20 seconds booting is nothing wrong with Right? You have time to watch tv, so the 20 seconds for booting is nothing)
