Posts by Lucky13
    My Z12 has been rock solid connected via ethernet but today the apps including mytv is saying not connected to Internet. Ive tried it on WiFi too but no apps are connecting to the net. The box setting clearly shows that it is connected to to router with excellent strength.
    Ive rebooted everything but the apps will not connect.
    Any advise please?
    Thank you
    Reboot router first. Then put on z12 if router is fully online and then connect ethernet cable. Turn wifi off on box and click on dhcp in ethernet settings and see if you get an ip addres.
    choose at private dns hostname quad9.
    I’m using a Formuler Z11 Pro Max BT1.
    All firmware updates are installed, and I’m currently running the beta version.
    In MyTVOnline3, Timeshift is enabled and working correctly. However, I have to manually activate Timeshift every time I start a channel or switch channels. When changing channels, I’m forced to disable Timeshift first, otherwise channel switching is blocked.
    I’ve seen references indicating that Timeshift can be set to activate automatically, but I cannot find this option anywhere. When I enable Timeshift in MyTVOnline3, I only get a simple ON/OFF toggle — no “Automatic” or “Manual” mode is available.
    Is there a way to enable automatic Timeshift on the Z11 Pro Max, or is this feature restricted by the portal/provider configuration?
    Any help would be appreciated.
    Make an backup of mytvonline3 with usb stick via mytvonline3 menu.
    Delete/uninstall mytvonline3
    Reboot device
    Install mytvonline3 via market app
    Import via usb your backup.
    If problem still exist, uninstall mytvonline3 without making a backup.
    Reboot device and install via Market app again.
    Don't install beta (if available)
    If then still exist, then i think you need to do factory reset.
    All apps are working... BUT I would like them in "Market"...
    if I have them on a USB stick, then forget to remove the stick when at a clients house... I will be Peeeed off!
    I sometimes forget to take my Amnesia medication......
    I will ask for you if my package was okay (if you tested it) and all apps could installed and worked on box your box.
    If yes, i can ask a dev to download the package and upload them to market
    I used to be able to find all the Apps via my Play store.... but then some were not available....
    on the z8.. all were there... when I upgraded to z12, most were there and the last load of new boxes, there were even fewer apps available.
    Ah okay. But now your list is complete and you have all apps?
    Do all apps working?
    Thanks for your time and efforts! I really appreciate it!
    iPlayer is available in Aptoide.. chan4 and ITVx too sky news too...
    It would make my life easier if the Owners just put the apps into "Market"...
    Again... Thanks!
    Thanks my friend, i saw the list and searched for all.
    And know you find it yourself using aptoide:grinning_squinting_face:
    Did you miss an app yet? Or is your list now complete?
    Can someone help me. I can't find the refresh button for the providers or am I missing something.
    And thanks for the answers
    When watching channel.
    Press once ok button.
    Press to the left, and press again to left. You see now providers etc.
    Go to the 3 dots upper left corner
    Click on it and refresh.
    For vod or series almost the same steps. Go first to vod.
    Then the steps.
    P.s: hope in future the refresh button will come back in main menu. And that it refresh all. So all channels, epg, vod and series together in one)
    When I turn on tv and formuler always says no power from hdmi when both are turned on have to plug out power cable from formuler box then it works
    Any recommendations??
    Turn off hdmi cec.
    Turn first tv on. Then 5 seconds later the box.
    Or try the box to set it in standby.
    Looks like tv and box don't have a good "hand shake".
    Try it with hdmi cec on (on tv and box together ofcourse) also.
    My remote z12 died overnight.
    Nothing works anymore. Changed the batteries, removed the new one's couple of times but it stayes dead.
    Also the command-light is not there anymore.
    Anyone here maybe a good solution??
    Thx already
    It looks dead to me.
    Alkaline (not zinc) batteries in and try.
    Or try to reset. Hold 0 (zero) and OK button in for 3 seconds.
    If no lights? It's dead.
    Buy new one and or contact seller for warrenty
    Here the whole package.
    App package
    9 files sent via WeTransfer, the simplest way to send your files around the world
    we.tl
    I didn't test it. I created only the apk files. 2 hours of my time.
    So you may test it and i also dont know if it's geo-blocked.
    Anyway.
    Friend F_Peter can download it too, install it and open the apps and if they open and working, he can upload them to the market app.😃✅️
    Goodday my friends
    For bbc iplayer i had no time anymore.
    Almost done,
    Converted all. But didn't test it.
    2 hours busy with it. Missing only bbc iplayer. Rest i have.
    Maby it's geolocked etc. You download the package later and test it yourself.
    Okay? I did my job.
    Goodday. Post it tonight.
    Busy with downloading the apps and try to make apks from it.
    So far i downloaded and installed here in my country.
    Itvx (bad ratings)
    Sky news (bad ratings)
    Watch free uk (bad ratings)
    Radio.net
    Quad9
    ARD Mediathek
    My5
    zdf
    How i do it?
    Nordvpn obfuscated server to united kingdom.
    And change language box to english.
    And change google account to united kingdom.
    Bbc iplayer is hard to find
    channel 5 etc have to search. Busy with it
    Its exactly the same Google account.... same vpn router.. same remote...
    One box will find the apps the other wont!
    I think I have the APKs on a USB somewhere......
    Strange my friend, hope you find the usb. Same account and boxes but the apps are not to find on one box🤣
    And or try to remove latest updates from google play store. Maby is one z12 play store updated and had a bug that some apps are missing?
    Any ideas why when I connect one of my z12 I can download the ITVx app.. Chanel4 and My5 ... But on another z12, i Can not find them in the google play store.
    The only thing thats different is the z12... Internet is the same... VPN is a UK dedicated VPN set in Manchester ( Not surf shark or express... Truely private)
    Any info would be greatly appreciated...
    As for Wifi dropping... I have had this several times...
    Is the other z12 logged in with an google account with another country?
    If you are handy you can with apps like luckypatcher make an apk file on the z12 with the installed apps you want. Put them on usb and try install on other z12. Difficult job, but it works most time.
    Ok
    I setup in menu that i want norway subtitle on movies, series but never start, i must go on top to select, will it not select the default sub automatic?
    In mol3 there are subtitle options.
    Set player to norwegian language.
    And subtitles deselect all, only select norway.
    And there should be option to select norwagian as default subtitle and audio language as English.
    Should check it later. Im gonna eat now my friend.
    Thank you i change to stalker portal, and use Myonline3 on iphone with same mac address and it works good. And play on both if is on same wifi, but stop 1 second some time. Can Myonline3 on formuler have more than 1 pip picture? I will check if it hang on Movies and series later
    1 connection on 2 devices at the same time give freezes, buffers and flashes.
    1 device at the time on.
    I have 3 subs from different providers. All EPGs are set to "Alternate". Neither one is showing a date for "Refresh EPG Data". I performed the "Clear and Update EPG All" function. Waited a considerable amount of time, but EPG never repopulated. I did a force stop and clear cache of MTOL4, followed by a reboot of Z12. EPG did repopulate after this, but still no date for "Refresh EPG Data".
    Wait for the automatic update settings time in mol3/mol4.
    When the time was past next day at 1600 hours it worked at my side.
    But you need auto update settings setup in mol as scheduled refresh and then wait till next day.
    That worked out for me🤷🏻‍♂️
    Will Formuler ever release a enigma2 dvbc cable Reciver or sat reciver again? Maybe a F5 with both enigma2 and android multiboot?
    Should also be nice with a place for harddisk.
    :smiling_face:
    I don't know.
    The last years it's all Android boxes. But who knows if one is coming out for cable tv
    Calm down please. We are here to help you my friend.
    Can you type your url here? And hide the credentials with xxx etc.
    Maby it's just a stupid slash / and or credentials like L is l or i etc.
    Url you can teatv yourself is browser. Its says then: unautorized.
    Some urls has :80 begind it. Remove etc. Try please.
    Clear data last step.
