Yes, beta mol4 is offline.
It was pure for the testers. Then they decide to take it offline.
Display MoreUh oh! Tried to clear EPG and reload using the menu option in the Live TV section and now I seem to be stuck in a boot loop!
Have tried stopping the app and clearing cache then opening again.
Also tried stopping app, clearing cache and restarting box.
I guess next step is to try a reinstall?
How do I do that?
https://www.dropbox.com/scl/fi/13omsqa…t=jb33nbcr&dl=0
Clear data last step.
I've searched everywhere and tried the 3 downloader codes Ive found. 28907 (FirestickStore), 75726 (DocSquiffy) and 82914 (Official) and all 3 fail when installing. Any pointers would be greatly appreciated.
Mytvonline is only designed for Formuler boxes!
And mobile phones and tablets.
No firesticks etc.
i did all that i knew its something else ,i tough you guys have a solution for this on z 10 i knew how to get on hiden menu and erase the codes.but thanks for your help.
Go out off mol3!! Go to desktop first!
Exit mol3!! First exit mol3 and or push on remote on "house" button (under OK button).
Then take picture for us!!!
Display MoreHi Lucky133,
All sorted from your LINK...!!!
BRILLIANT and Latest NordVPN screen CHEERS...!!!
Why don't Formuler Z12 Ultra have the latest S/W not Feb 06 2024 like it says in Market place ( JOKE )...
THANK YOU AGAIN
Lucky133
P
Glad you fixed it my friend!
Goodday
Always download from google play store my friend
Could somebody Help please, i have put Nordvpn on my Formuler Devices for years. But, I have just done a Reset of the Z12Ultra and when I have put NordVPN back on, it won't let me log in.
It goes to the Verify you are human screen which I tick, then it keeps going back to that screen and won't let me log in...???
Cheers in Advance
Popeye05
Install nordvpn from google playstore. Not from formuler market app.
I will try it today myself to remove nordvpn and install it again and have a look if i got the message too.
Or remove nordvpn and download the apk from there official website and try that one please.
https://downloads.nordcdn.com/apps/android/generic/nordvpn-sideload/latest/v2/NordVPN_TV.apk
Thank you Sam for suggestion. I was able to install TizenTube and it works fine. Haven't played around much, hope the content is same and only the front end UI is different.
Content should be the same
its nothing there. he have the portal locked somehere.i knew how to unlock it on formuler z10 but i dont have no ideia how to do it on 11.It is called FastCode and it is a feature of MyTvOnline. I don’t know how it is set from the provider side but it permit to the provider to manage himself the changes of link for example. An auto-update of the link is made so the user don’t have to take care of it. friend a mine bought 4 boxes formuler z11 pro and give it to me .so we dont knew who was the provider for that portal,i am going to be stuck with 4 boxes that i can not use the mytv online.lol
They cant block all.
Youn should get into the menu at cogwheel on homescreen etc.
and can not change anything on portal this locked somewhere and i can not find it
Push first on home (house) button.
Go out of mytvonline3.
So you see the desktop with the buttons.
Go to Settings (not mytvonline settings!) > Storage & Reset on your Z11.
If a block is installed, you will see an option to "Check for configuration update".
Highlight the configuration line, then press the 0 (zero) button 10 times on your remote. This will perform a factory reset and remove the block.
Don't believe it, it's a brand new box. It's the best box they have with Dolby atmos, dolby vision etc. And mytvonline4 beta. Why discontinue then?
And if so they stopped then maby temporary due high prices for cpu, ram and storage chips etc.
But I think it's not real.
Let's wait what SAM and or other Formuler employees says.
Has it been posted how to "Un hide" a country/group?
While watching a channel, press ok button. Press to the left, go to the 3 dots left upper corner, show & hide groups.
Goodluck and goodday my friend
I think the application is good but I think it needs to be improved.
-To create a list of favorites I find it too complicated compared to mitv3 too much maneuver to do
-The back button in the VOD app to return to the home screen it would be good if it came back.
VOD and SERIES it will be good to have several lines instead of one line.
Ofcourse it needs to be improved. It's a beta version.
From vod back to live push menu button temporary, till they fix it to the "back" button
Goodday my friend
I have this too,occasionally,if possible i will send logs,thank you
Me too. Also when i fully shutdown box.
And boot later and or the next morning the box again and i start mytvonline4 i starts with homescreen. And not LIVE what i setup in settings.
Hi I was watching tv and this came up in my screen
Server down dns or portal...
Try reconnect and or contact provider.
Any suggestions Netflix freezing go into app and can’t scroll just stuck on home page
When re download says system doesn’t support app 🤔
Netflix should only work from the Formuler market app.
And control it with a mouse and keyboard.
Cleared cache and data and now all good.
EdiG
Good job, well done!
Goodday my friend. Have fun with Mol4!
I successfully installed the beta and was using it quite happily until yesterday. Unfortunately it seems to be stuck in a startup loop which I can't get past. It shows the mytvonline 4 screen then momentarily shows the home screen before looping back to the startup. I've tried deleting the cache to no effect. I also tried without internet and I get an error message but no further.
What can I do to restore the app?
Hello my friend,
You can't make an backup anynore. Cause it won't start i read.
Reboot box first and try again.
If not work? Press twice (2x) on home button (house) and then on the red button. (You close all open apps now)
Try again mol4.
If problem still exist...
You can try only 1 thing: clear the cache and then clear data from mol4.
Reboot system and try again to start mol4.
Goodday and Goodluck my friend.
Please give me feedback
and to erase a string in a favorite list that no longer works? thanks
Press ok button on channel what don't work.
You see channel list and channel what not work is already selected.
Press blue button on remote my friend...
...and it’s gone.
Okey Will try that
According reddit it's not a Formuler or other brand problem. But an Prime problem.
Hi.
I wonder if someone can play movies on Amazon Prime in 4k on Formuler Z12 ultra?
I know it’s not working on Netflix.
But Disney works and hbo max should be fine. YouTube works and Viaplay 4K works.
I don't have prime.
But disney works with 4h and dolby atmos and dolby vision (if movie supports it)
Skyshowtime is in 4k.
So i think Prime should be in 4k too if the movie supports it.
I never thought i would write this but i miss Notifications,in order to check whether refresh contents was succesful.
Furthermore, i would like to see reminders/recordings not depicted by a red beam on top of grid epg,but with a fat red dot on the specific channel chosen.
When possible, one refesh contents button for all providers.
Finally make this beta ASAP Official and finetune/tweak it in faster future updates(Great work from the devs
Notifications are on homescreen my friend. See the bell next to mol4 logo.
Yes, i asked too for 1 refresh button in menu that refresh ALL your providers, channels, vod/series and epg.
But for now it's doing that itself everday at 16.00 hours refreshing all subs. I had that already setup in mol3. Auto refresh every day at 16.00 hours.
it seems to me that TizenTube is much better than SmartTube. So why not implement it as well with MyTVOnline beta 12 ?
Maby an option yes for future update.
But smarttube is lightweight and updated weekly/monthly by itself.
Hi
Before I upgrade, I’d like to know if it’s still possible to download subtitles from OpenSubtitles in the new version?.Could you please make it possible to add an extra link for the EPG on the portal? That’s what I’m missing on mytvonline, and I’d also like to be able to reorder the channels .
Yes still possoble ofcourse my friend.
I hope one single refresh button back in the mol4 menu.
One click on it and it refresh all providers live, vod, series and epg in once.
same problem i make ticket because is harware problem i think
SAM can you help me please
Maby it's rolled out in batches like google play do with new updates...
If you are going to install that, everything will remain your favorites or you will have to do everything again.
All remain my friend
Is there a way to go back to mytvonline3 I don’t like the new mytvonline4 app
It's clearly explained on forum that it is not possible.
Also before you installed mol4, you are warned 2 times or so.
Also you typed 1339 beta code yourself...
Since Yesterday ?
Yesterday evening european time belgium it worked out for me.
Maby delete cache from software updater app and restart box.
I installed MYTV4 on a Z 12 ULTRA to test it, and then I reset it to factory settings.
Now I can't download mytvONLINE anymore.
Can you help me?
Software update, 1339 code and then you should see logo above.
If not, they take it maby offline. Maby they are busy with it my friend.
Try again later.
Hi Lucky,
follow the steps as shown on the pics I am attached.
Good night
Goodday my friend, thanks for your feedback.
But i had it already on mytvonline3 setup at 16.00 hours every day.
But thanks my friend.
Goodnight for now, speak you later my friend.
MOL4 menu -> App Settings -> Content Sources -> click on Portal -> refresh contents.
MOL4 seen today for first time the world as Beta and will be continuously extended and updated. New sections will come and some changed, like each MOL before. My personal opinion in all this years, this will be the best MOL since beginning, i like it very much.
Yes okay, but i ment a refresh button for ALL my portals. So from all the portals the live, vod and series will be refreshed.😃
Bug: Pressing ‘back’ when in vod groups would bring back to live tv, it’s now acting as the ok button.
Found it out yet yes.
But it's beta. So it will be fixed✅️
You can't go back from vod to live.
And how to refresh all live, vod, and series in one time? So far i see it's only available per section.
Or am i wrong.
Hello Sam, will MYTVOnline 4 be made available in Z11 Pro Max in a later release?
I think (know almost sure) it's only for the Z12 ultra
Thanks Lucky just what i thougt. Need to download the standalone version not from the market.
The one from market there was the the package signature from stolen.
So the creator of the app needed to create another new signature and uploaded app on github.
Now has formuler it fixed an can you use the new smartube. Check omin settings at INFO (smarttube) at update notification and turn it on my friend.
Goodday
Remove old one.
Install new one.
https://github.com/yuliskov/SmartTube/releases/download/latest/smarttube_stable.apk
The new one is being updated every month almost.
Can upload a video is 70 mb ?
Try it.
And update is coming my friend...
Please have patience
