Posts by inspectaclueso
    Hi Inspecta,
    If buffering only occurs every minute or so it's a bit différent than other issue where it buffers egery 5/10 seconds.
    Have you tried to expand buffer size in options ?
    Do you use ethernet cable instead of WiFi ?
    Hi Dicentim
    The last few days I have had some buffering on a couple other devices while testing so could possibly be a channel issue. A strange coincidence it didn't do it when I changed devices originally. Yes, I've set the buffer size to 10 seconds. I always use ethernet cable on a Gigabit network (I know Z7+ limited to 100).
    I'm having the same issue.
    Z7+ using the latest firmware/software. Have performed factory reset, removed microSD and have set ethernet to static IP.
    I get buffering/loading for a couple seconds every minute or so.
    It happens with multiple providers however when I switch to HTPC with Kodi I do not get buffering. Same network, same ISP, same channel... only difference is the device used to watch.
