Excuse me, did anyone update with this firmware?
Does the Italian TV sat card with the MCAS work?
But the problem is with tvsat?
Ma parli di scheda tvsat o altro?
Hallo, I have 1.6.28 firmware and the tvsat card work ok with Mcas plugin. This decoder has many stability problem....
Ciao, non ho piu' aggiornato il firmware. Sono fermo alla 1.6.28 e con questa versione e il plugin Mcas , la tessera tvsat funziona. Questo decoder mi sembra abbia tanti problemi e quindi cerco di "toccarlo" il meno possibile.
Tu hai mai avuto il problema che ho indicato sopra, ossia che disallinea il nome dei canali (come da foto)?
Hallo,
I've upload a setting made with ClarkeTech editor studio. All is ok, but after a few days of use, the "channel name" show is wrong (usually it is one o two channel before).
To explain I've attached an image:
Fashion 4K : on left list and in the small channel view
Test UHD3: in the right description
(the same thing happens in the normal view)
I've tried with differt setting, but it is ok for a certain period but after the name is misaligned.
Any suggestion?
Thank!
Yes confirm that new sw don't work with mcas app (card TVsat).
Firmware version is 1.6.11.
Rob
Only for information to analyze the issue.. before to try a factory reset (I prefer to leave as last resort..) I've made other tests:
If I stop or put in stand by the box by RCU (using popup menu) and after unplugged cord, mostly when I power on the box loop boot.. but if I put the box in standby using the right side button on formuler, when I replugged, the box correctly start and re-goes in standby (boot, goes to channel and after to standby displaying hour).
Could it be a software problem?
Rob
I haven't done a factory reset (the formuler is new.. I've only upgrade firmware), but I can try..
Meanwhile I send short video. The formuler start, go to channel (0103) ... go to hour and reboot. Sometime after two/three loop, it stops. Other time goes on forever..
Rob
my Formuler s when I power on it (same tv outlet) , almost always, boot , go to the last channel .. and reboot go to channel...and reboot... I must put it in standby manually when I can...
Any ideas? In this way I must leave the equipment always connected to power (I usually disconnect all during night or while I'm out).
Thanks, Rob
