Loop reboot
  • Hi,
    my Formuler s when I power on it (same tv outlet) , almost always, boot , go to the last channel .. and reboot go to channel...and reboot... I must put it in standby manually when I can...
    Any ideas? In this way I must leave the equipment always connected to power (I usually disconnect all during night or while I'm out).
    Thanks, Rob
  • Hello,
    I haven't done a factory reset (the formuler is new.. I've only upgrade firmware), but I can try..
    Meanwhile I send short video. The formuler start, go to channel (0103) ... go to hour and reboot. Sometime after two/three loop, it stops. Other time goes on forever..
    Rob
    FS.zip
  • Hello,
    Only for information to analyze the issue.. before to try a factory reset (I prefer to leave as last resort..) I've made other tests:
    If I stop or put in stand by the box by RCU (using popup menu) and after unplugged cord, mostly when I power on the box loop boot.. but if I put the box in standby using the right side button on formuler, when I replugged, the box correctly start and re-goes in standby (boot, goes to channel and after to standby displaying hour).
    Could it be a software problem?
    Rob
